[geos-devel] Re: [GEOS] #523: SymDifference between two valid
geometries return
an _invalid_ geometry [JTS fails too] (was: SymDifference between
two valid geometries return an _invalid_ geometry)
geos-trac at osgeo.org
Fri Mar 30 07:07:22 EDT 2012
#523: SymDifference between two valid geometries return an _invalid_ geometry
[JTS fails too]
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.3
Component: Default | Version: 3.3.2
Severity: Unassigned | Keywords: jtsfail
Changes (by strk):
* keywords: => jtsfail
Comment:
I've tested JTS which also fails. Not easy to tell because JTS testrunner
doesn't check output for validity, but it succeeds in returning the
invalid geometry as result.
Ticket URL: <http://trac.osgeo.org/geos/ticket/523#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
