[geos-devel] [GEOS] #535: error running make check
GEOS geos-trac at osgeo.org
Thu May 3 10:52:05 EDT 2012
 Reporter:  aaronharris  |       Owner:  geos-devel@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  3.3.4
Component:  Default      |     Version:  3.3.3
 Severity:  Unassigned   |    Keywords:
 i have just installed from source version 3.3.3 on centos64.  I am getting
 the following error when running make check.  Is there a dependency that I
 missed?
 make[3]: Entering directory
 `/usr/local/src/geos-3.3.3/geos-3.3.3/tests/xmltester'
 lt-XMLTester: GeometryComponentFilter.cpp:35: virtual void
 geos::geom::GeometryComponentFilter::filter_ro(const
 geos::geom::Geometry*): Assertion `0' failed.
 ./testrunner: line 2: 19874 Aborted                 (core dumped)
 ./XMLTester -v --test-valid-output ./tests/testLeaksBig.xml
 ./tests/split.xml ./tests/hexwkb.xml ./tests/test.xml
 ./tests/linemerge.xml ./tests/TestIsValid.xml ./tests/robustness.xml
 ./tests/buffer.xml ./tests/singlesidedbuffer.xml ./tests/ticket/bug176.xml
 ./tests/ticket/bug188.xml ./tests/ticket/bug244.xml
 ./tests/ticket/bug275.xml ./tests/ticket/bug350.xml
 ./tests/ticket/bug356.xml ./tests/ticket/bug358.xml
 ./tests/ticket/bug360.xml ./tests/ticket/bug366.xml
 ./tests/ticket/bug392.xml ./tests/ticket/bug398.xml
 ./tests/ticket/bug434.xml ./tests/ticket/bug488.xml
 ./tests/general/TestBoundary.xml ./tests/general/TestBuffer.xml
 ./tests/general/TestBufferMitredJoin.xml ./tests/general/TestCentroid.xml
 ./tests/general/TestConvexHull.xml ./tests/general/TestConvexHull-big.xml
 ./tests/general/TestDistance.xml ./tests/general/TestFunctionAAPrec.xml
 ./tests/general/TestFunctionAA.xml ./tests/general/TestFunctionLAPrec.xml
 ./tests/general/TestFunctionLA.xml ./tests/general/TestFunctionLLPrec.xml
 ./tests/general/TestFunctionLL.xml ./tests/general/TestFunctionPA.xml
 ./tests/general/TestFunctionPLPrec.xml ./tests/general/TestFunctionPL.xml
 ./tests/general/TestFunctionPP.xml ./tests/general/TestInteriorPoint.xml
 ./tests/general/TestRectanglePredicate.xml
 ./tests/general/TestRelateAA.xml ./tests/general/TestRelateLA.xml
 ./tests/general/TestRelateLL.xml ./tests/general/TestRelatePL.xml
 ./tests/general/TestRelateAC.xml ./tests/general/TestRelateLC.xml
 ./tests/general/TestRelatePA.xml ./tests/general/TestRelatePP.xml
 ./tests/general/TestSimple.xml ./tests/general/TestUnaryUnion.xml
 ./tests/general/TestUnaryUnionFloating.xml ./tests/general/TestValid.xml
 ./tests/general/TestValid2.xml ./tests/general/TestValid2-big.xml
 ./tests/general/TestWithinDistance.xml ./tests/stmlf/stmlf-
 cases-20061020.xml ./tests/stmlf/stmlf-cases-20061020-invalid-output.xml
 ./tests/stmlf/stmlf-cases-20070119.xml
 ./tests/robust/TestRobustOverlayFixed.xml
 ./tests/robust/TestRobustRelate.xml ./tests/fme.xml
 ./tests/TestBufferExternal.xml ./tests/TestBufferExternal2.xml
 ./tests/heisenbugs.xml ./tests/badguy3.xml ./tests/hole_from_shell.xml
 ./tests/hole_red.xml ./tests/safe/16595.xml ./tests/safe/16596.xml
 ./tests/safe/TestBufferJagged.xml
 FAIL: testrunner
 1 of 1 test failed
 make[3]: *** [check-TESTS] Error 1
 make[3]: Leaving directory
 make[2]: *** [check-am] Error 2
 make[2]: Leaving directory
 make[1]: *** [check-recursive] Error 1
 make[1]: Leaving directory `/usr/local/src/geos-3.3.3/geos-3.3.3/tests'
 make: *** [check-recursive] Error 1
Ticket URL: <http://trac.osgeo.org/geos/ticket/535>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
