[geos-devel] Re: [GEOS] #534: Cross compile trunk for android
geos-trac at osgeo.org
Fri May 4 02:55:08 EDT 2012
Reporter: mbernasocchi | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.4
Component: Default | Version: svn-trunk
Severity: Significant | Keywords: android
Comment(by strk):
I see the cross-compiling error is part of the macro (which is taken from
postgresql, btw):
AC_TRY_RUN(
dnl We will do better here with Autoconf 2.50
AC_MSG_WARN([64 bit arithmetic disabled when cross-compiling])])])
Are you saying you didn't get that message with 3.2.2 ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/534#comment:5>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
