[geos-devel] [GEOS] #540: C-API: Allow passing custom memory
managment functions
geos-trac at osgeo.org
Fri May 4 08:49:15 PDT 2012
#540: C-API: Allow passing custom memory managment functions
Reporter: strk | Owner: geos-devel@…
Type: enhancement | Status: new
Priority: major | Milestone: 3.4.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
We could take custom allocator and deallocator functions for use while
using the C-API. Doing so PostGIS (for example) could use the memory
poolers provided by PostgreSQL catching any leak at statement end and also
allowing for query interruption (see
http://trac.osgeo.org/postgis/ticket/1802)
Ticket URL: <http://trac.osgeo.org/geos/ticket/540>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
