[geos-devel] Re: [GEOS] #540: C-API: Allow passing custom memory managment functions
GEOS geos-trac at osgeo.org
Sat May 5 08:59:28 PDT 2012
 Reporter:  strk         |       Owner:  geos-devel@…
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  3.4.0
Component:  Default      |     Version:  svn-trunk
 Severity:  Unassigned   |    Keywords:
Comment(by pramsey):
 I did this once upon a time because I thought it was the only way to stop
 leakage in the prepared geometry code. It mostly worked (though I was
 plenty worried about it) with the exception of the global geometryfactory
 declared in the capi which persistently got instantiated in system memory,
 not in the postgres pools.
Ticket URL: <http://trac.osgeo.org/geos/ticket/540#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
