[geos-devel] [GEOS] #546: polygonize::EdgeRing::ptNotInList bug ?
Martin Davis mtnclimb at telus.net
Mon May 14 22:18:12 PDT 2012
Actually this code is no longer used in JTS, and should be deprecated.
It's been refactored into CoordinateArrays (for which there is a unit test).
Even better would be a polygonize test which triggered this failure.
There isn't such a test case in JTS, however.
>   Reporter:  strk        |       Owner:  geos-devel@…
>       Type:  defect      |      Status:  new
>   Priority:  major       |   Milestone:  3.3.4
> Component:  Default     |     Version:  3.3.3
>   Severity:  Unassigned  |    Keywords:
>   The current polygonize::EdgeRing::ptNotInList seems to be calling
>   EdgeRing::isInList in the wrong way (not negating its return code).
>   JTS does it the other way (negates its return code).
>   There's no test failing, which doesn't help.
>   The first step would be producing a failing test case
>   Martin: can you help with that?
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2012.0.2171 / Virus Database: 2425/4998 - Release Date: 05/14/12
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20120514/3877dc47/attachment.html
