[geos-devel] [GEOS] #509: GEOS crashes on check in MingW GCC 4.6.2
geos-trac at osgeo.org
Mon May 28 06:17:59 PDT 2012
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.4
Component: Default | Version: 3.3.3
Severity: Unassigned | Keywords:
Comment(by strk):
Uhm, the NaN test in trunk is protected by:
#if defined(__STDC_VERSION__) && __STDC_VERSION__ >= 199901L
Does it seem a sensible workaround ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/509#comment:6>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
