#509: GEOS crashes on check in MingW GCC 4.6.2
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.4
Component: Default | Version: 3.3.3
Severity: Unassigned | Keywords:
Comment(by strk):
The code in trunk comes from r3469 committed by Mat specifically to
workaround VC++ builds...
Worth backporting ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/509#comment:7>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
