[geos-devel] how to know if two linestrings "really" cross each other
Martin Davis
mtnclimb at telus.net
Wed May 30 13:26:52 PDT 2012
The DE-9IM model isn't designed to be able to distinguish between these
two cases, so there's no way to compute this by using any of the named
predicates, or even a custom relate matrix.
You could do this via some fairly straightforward custom code. The
algorithm is:
- identify vertices in each linestring which are coincident
- build a simple "local topology" for the 4 incident line segments at
each intersection
- examine the intersection to see if the segments alternate or are
adjacent (you can do this by using the angles of the segments)
On 5/30/2012 3:40 AM, Jasmin FORMONT wrote:
> Hi everyone
> I can't find a way to tell if two linestrings "really" cross each other.
> For instance if I have this linestring :
> Line1 : LINESTRING(0 0, 1 1, 2 0)
> How can I differentiate the relation of line 1 with one of the following :
> Line2 : LINESTRING(0 2, 1 1, 2 2) -> no "real" cross, just a
> contact point
> Line3 : LINESTRING(0 2, 1 1, 1 0) -> lines "really" cross each other
> I can't find a good combination of crosses, touches, etc... to
> differentiate these cases.
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20120530/49737828/attachment.html>
