[geos-devel] how to know if two linestrings "really" cross each other
Todd Jellett todd.jellett at caris.com
Thu May 31 05:25:21 PDT 2012
This algorithm will work if you can guarantee that there will be no
overlapping line segments on your linestrings. If overlaps are possible,
you will get a mixture of 4 line segment intersections and pairs of 3
line segment intersections with overlap between them.
To robustly determine if you have a transverse intersection between 2
linestrings:
- create a circle centered at the intersection point (4 segment case) or
at the start and end of the overlap interval (3 segment case)
- decompose each circle into two circular arcs where one line string
intersects the circle
You have a transverse intersection if the incoming line segment of the
other linestring intersects a different circular arc than the outgoing
line segment.
On 30/05/2012 5:26 PM, Martin Davis wrote:
> The DE-9IM model isn't designed to be able to distinguish between
> these two cases, so there's no way to compute this by using any of the
> named predicates, or even a custom relate matrix.
> You could do this via some fairly straightforward custom code.  The
> algorithm is:
> -  identify vertices in each linestring which are coincident
> - build a simple "local topology" for the 4 incident line segments at
> each intersection
> - examine the intersection to see if the segments alternate or are
> adjacent (you can do this by using the angles of the segments)
> On 5/30/2012 3:40 AM, Jasmin FORMONT wrote:
>> Hi everyone
>> I can't find a way to tell if two linestrings "really" cross each other.
>> For instance if I have this linestring :
>> Line1 : LINESTRING(0 0, 1 1, 2 0)
>> How can I differentiate the relation of line 1 with one of the
>> following :
>> Line2 : LINESTRING(0 2, 1 1, 2 2)    -> no "real" cross, just a
>> contact point
>> Line3 : LINESTRING(0 2, 1 1, 1 0)    -> lines "really" cross each other
>> I can't find a good combination of crosses, touches, etc... to
>> differentiate these cases.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20120531/0285bcc8/attachment.html>
