[geos-devel] Buffer extends beyond flat end caps
Martin Davis mtnclimb at telus.net
Wed Oct 10 20:48:49 PDT 2012
Confirmed, this is an issue in GEOS and JTS (all versions).
This is due to some limitations in the current algorithm for generating
buffer offset curves with flat ends for lines with relatively short
segments at the end.  Hard to say how easy this will be to fix -
sometimes these kinds of issues are surprisingly tricky to handle.
Martin
On 10/10/2012 6:18 PM, Mike Toews wrote:
> LINESTRING(33.193 54.345, 33.148 54.362, 30.646 55.565, 29.949 56.163,
> 29.351 56.676)
