[geos-devel] [GEOS] #585: mingw64 trunk make check fail on badthreadtest
geos-trac at osgeo.org
Fri Sep 7 23:15:43 PDT 2012
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone: 3.4.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
strk,
Okay I've had enough of these false warnings. I think you and Mat decided
this was not a mingw64 only issue, and that it shouldn't even be going
into this loop and there is something wrong with your arm configure
script. Error:
make threadtest.exe badthreadtest.exe
make[4]: Entering directory `/c/jenkins/geos/branches/3.4/tests/thread'
x86_64-w64-mingw32-gcc -DHAVE_CONFIG_H -I. -I../../include
-I../../include/geos -I../../include -I../../tests/unit/tut -I../../capi
-pedantic -Wall -ansi -Wno-long-long -ffloat-store -g -O2 -MT
threadtest.o -MD -MP -MF .deps/threadtest.Tpo -c -o threadtest.o
threadtest.c
In file included from
c:\ming64\mingw64\bin\../lib/gcc/x86_64-w64-mingw32/4.5.4/../../../../x86_64-w64-mingw32/include/unistd.h:10:0,
from threadtest.c:19:
../../include/geos/io.h:19:11: error: expected '=', ',', ';', 'asm' or
'__attribute__' before 'geos'
In file included from ../../include/geos/io.h:48:0,
from
c:\ming64\mingw64\bin\../lib/gcc/x86_64-w64-mingw32/4.5.4/../../../../x86_64-w64-mingw32/include/unistd.h:10,
../../include/geos/io/ByteOrderDataInStream.h:30:61: fatal error: iosfwd:
No such file or directory
compilation terminated.
make[4]: *** [threadtest.o] Error 1
make[4]: Leaving directory `/c/jenkins/geos/branches/3.4/tests/thread'
make[3]: *** [check-am] Error 2
make[3]: Leaving directory `/c/jenkins/geos/branches/3.4/tests/thread'
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/c/jenkins/geos/branches/3.4/tests'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/c/jenkins/geos/branches/3.4'
make: *** [check] Error 2
Full gory details here:
http://winjen.postgis.net:1500/view/GEOS/job/GEOS_Trunk_ming/30/console
It should automatically rebuild after you commit a change. Well within 15
minutes, but you can manually build. You know the account.
Ticket URL: <http://trac.osgeo.org/geos/ticket/585>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
