[geos-devel] [GEOS] #588: valid polygon when cw, not valid when ccw
geos-trac at osgeo.org
Wed Sep 12 03:25:58 PDT 2012
Reporter: olivier80 | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.6
Component: Default | Version: 3.3.5
Severity: Unassigned | Keywords:
Comment(by olivier80):
Unfortunately, I'm not a postgis user, I use geos with the C api. This
polygon is a simplified version of a GEOSBufferWithStyle() result. I keep
only the problematic points (87.9271046586986810 -10.5302909001479570 and
87.9271046586986810 -10.5302909001479530). The distance between those two
points is nothing and yes, you're right, simplifying should fix.
Ticket URL: <http://trac.osgeo.org/geos/ticket/588#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
