[geos-devel] [GEOS] #589: GEOSBufferWithStyle with mitre style on LinearRing
geos-trac at osgeo.org
Wed Sep 12 03:47:39 PDT 2012
Reporter: olivier80 | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.6
Component: Default | Version: 3.3.5
Severity: Unassigned | Keywords:
I’m not sure if it is a bug or if it is normal behaviour.
Consider this linearring.
LINEARRING (
10.0000000000000000 10.0000000000000000,
20.0000000000000000 10.0000000000000000,
20.0000000000000000 20.0000000000000000,
10.0000000000000000 20.0000000000000000,
10.0000000000000000 10.0000000000000000)
Now I do :
GEOSBufferWithStyle(linearring, 1, 3, GEOSBUF_CAP_FLAT,
GEOSBUF_JOIN_MITRE, 5)
Result :
POLYGON ((
9.0000000000000000 10.0000000000000000,
9.0000000000000000 21.0000000000000000,
21.0000000000000000 21.0000000000000000,
21.0000000000000000 9.0000000000000000,
10.0000000000000000 9.0000000000000000,
10.0000000000000000 10.0000000000000000),
(11.0000000000000000 11.0000000000000000,
19.0000000000000000 11.0000000000000000,
19.0000000000000000 19.0000000000000000,
11.0000000000000000 19.0000000000000000,
11.0000000000000000 11.0000000000000000))
The first and last points of my buffer are in flat style. I think on a
linearring, geos should use the join style, not the cap style for the
closing point.
Otherwise, how can I mitre the first point and last points on a linearring
Ticket URL: <http://trac.osgeo.org/geos/ticket/589>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
