[geos-devel] [GEOS] #588: [JTS fails] valid polygon when cw, not valid when ccw
geos-trac at osgeo.org
Thu Sep 13 00:54:30 PDT 2012
Reporter: olivier80 | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.6
Component: Default | Version: 3.3.5
Severity: Unassigned | Keywords: jtsfail
Comment(by strk):
Martin Davis wrote:
> Turns out that this isn't an issue in the trunk version of JTS
> (but it is in JST 1.12).
> This is probably due to the recent switch to using extended precision
> to compute determinant signs - which affects all intersection
computations.
> It would be good if GEOS switched to using this new more (fully?)
> robust technique as well.
See ticket #591 for that
Ticket URL: <http://trac.osgeo.org/geos/ticket/588#comment:6>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
