[geos-devel] [GEOS] #588: valid polygon when cw, not valid when ccw
Martin Davis
mtnclimb at telus.net
Wed Sep 12 20:43:51 PDT 2012
Turns out that this isn't an issue in the trunk version of JTS (but it
is in JST 1.12).
This is probably due to the recent switch to using extended precision to
compute determinant signs - which affects all intersection
computations. It would be good if GEOS switched to using this new more
(fully?) robust technique as well.
On 9/12/2012 7:25 AM, Martin Davis wrote:
> Yes, JTS has the problem too. Sigh.... I'll have to dig into it to
> find out why this is failing. I made some improvements to the
> orientation test recently which I thought would make it fully robust,
> but perhaps there's still issues. Or else something else is going on....
>> Reporter: olivier80 | Owner: geos-devel@…
>> Type: defect | Status: new
>> Priority: major | Milestone: 3.3.6
>> Component: Default | Version: 3.3.5
>> Severity: Unassigned | Keywords:
>> Comment(by strk):
>> The polygon ring has 7 points, but it's a 4 sides polygon. So 2
>> vertices
>> are very close to other vertices.
>> I'd love to have a function (in postgis) to analyze these cases and
>> answer
>> questions like: what's the minimum distance between two consecutive
>> vertices ? what's the minimum distance between any two vertices ?
>> Simplifying the geometry with a tolerance of 1e-10 is enough to fix
>> the
>> invalidity, but anyway the robustness problem exists. I didn't try
>> with
>> JTS but I suspect it may be an issue there as well.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2012.0.2221 / Virus Database: 2437/5263 - Release Date: 09/11/12
