[geos-devel] [GEOS] #588: valid polygon when cw, not valid when ccw
Sandro Santilli
strk at keybit.net
Thu Sep 13 00:50:40 PDT 2012
On Wed, Sep 12, 2012 at 08:43:51PM -0700, Martin Davis wrote:
> Turns out that this isn't an issue in the trunk version of JTS (but
> it is in JST 1.12).
> This is probably due to the recent switch to using extended
> precision to compute determinant signs - which affects all
> intersection computations. It would be good if GEOS switched to
> using this new more (fully?) robust technique as well.
Are you referring to this commit ?
http://jts-topo-suite.svn.sourceforge.net/viewvc/jts-topo-suite/trunk/jts/java/src/com/vividsolutions/jts/algorithm/CGAlgorithms.java?r1=652&r2=651&pathrev=652
Or which other else ?
--strk;
http://www.cartodb.com - Map, analyze and build applications with your data
~~ http://strk.keybit.net
