[geos-devel] [GEOS] #589: GEOSBufferWithStyle with mitre style on LinearRing
Martin Davis
mtnclimb at telus.net
Sun Sep 16 13:06:25 PDT 2012
Yes, that probably makes more sense. The only rationale for not doing
this already is that it will take some work to create offset linework
that reflects this logic. (Currently linearrings are handled by the
same code as linestrings, because when the end cap style is round the
ends merge seamlessly anyway. Cap styles were added later, but the
linearring handling was not enhanced to respect them).
> Reporter: olivier80 | Owner: geos-devel@…
> Type: defect | Status: new
> Priority: major | Milestone: 3.3.6
> Component: Default | Version: 3.3.5
> Severity: Unassigned | Keywords:
> Comment(by strk):
> Same issue exists with JTS. Martin: rationale for that ?
