[geos-devel] [GEOS] #589: GEOSBufferWithStyle with mitre style on LinearRing
geos-trac at osgeo.org
Sun Sep 16 13:33:40 PDT 2012
Reporter: olivier80 | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.3.6
Component: Default | Version: 3.3.5
Severity: Unassigned | Keywords:
Comment(by strk):
Martin said:
> Yes, that probably makes more sense. The only rationale
> for not doing this already is that it will take some
> work to create offset linework that reflects this logic.
> (Currently linearrings are handled by the same code as
> linestrings, because when the end cap style is round
> the ends merge seamlessly anyway. Cap styles were added
> later, but the linearring handling was not enhanced to
> respect them).
(it would be lovely if trac accepted mail replies, but unfortunately it
doesn't, so I'm copy&pasting mailing list only reply ..)
Ticket URL: <http://trac.osgeo.org/geos/ticket/589#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
