[geos-devel] Gsoc 2013
vishal tiwari
hi.vishal123 at gmail.com
Sat Apr 27 11:34:14 PDT 2013
Hey!
I have submitted my GSoC Proposal for the project "Adding Voronoi Diagrams
to GEOS" here:
http://www.google-melange.com/gsoc/proposal/review/google/gsoc2013/vishal_tiwari/13001
kindly review it and give me feedback so that i can further improve it
before the application deadline.
Thanks,
Vishal Tiwari
On 10 April 2013 15:38, Sandro Santilli <strk at keybit.net> wrote:
> On Wed, Apr 10, 2013 at 02:17:44PM +0530, vishal tiwari wrote:
> > Hey,
> > I suppose only those test cases needs to be ported that correspond to
> > Voronoi class. But i see many other test cases for other class that are
> > missing. So just asking for clarification, do we need to ported other
> test
> > cases as well?
> For the purpose of Voronoi you only need to port tests for the Voronoi
> class and any class used by the Voronoi class. But if you find yourself
> having more time porting more tests would be very useful
> > And as for the C-API this is what i have understood: it provides a
> wrapper
> > to the C++ functions. All the reference functions are implemented in
> > geos_ts_c.cpp. And all the functions that are exposed to the users are in
> > geos_c.cpp and its header file, geos_c.h.
> More or less. Actually geos_ts.cpp contains the _Thread_Safe_ (supposedly)
> version of the functions. It's been added later so the old API (officially
> non thread-safe) is retained. In theory, new functions could STOP exposing
> a non-thread-safe version of the signature but I haven't started this to
> avoid having a mix of new and old APIs around. So at the moment it's
> recommended to always keep both APIs.
> Both TS and non-TS function are found in geos_c.h. The non-TS function are
> all simple wrappers to the TS ones.
> > Regarding the Gsoc proposal in the 'Describe your idea' section of the
> > OSGeo proposal Application, this is what i have thought about from our
> > discussion on the project:
> https://docs.google.com/document/d/1biGlOqTnS7SnlxPOcFKrxj7_QEMYd1VtAFDms6L3AnY/edit
> Sounds good to me. Maybe Anne has some suggestions for the
> gsoc-specific needs.
> --strk;
> > Looking for your feedback on how it can further be improved.
> > Thanks and kind regards,
> > Vishal
> > On 4 April 2013 19:46, Sandro Santilli <strk at keybit.net> wrote:
> > > On Thu, Apr 04, 2013 at 05:02:56PM +0530, vishal tiwari wrote:
> > > > Hey,
> > > > Here is the structure of classes that is required by the *
> > > > VoronoiDiagramBuilder* class: (The ones in *bold* needs to be ported)
> > > > 1. Geometry
> > > > 2. Geometry Factor
> > > > 3. QuadEdgeSubdivision:
> > > > - Methods required for *VoronoiDigramBuilder*:
> > > > - *getVoronoiDiagram*
> > > > - *getVoronoiCellPolugons*
> > > > - *getVoronoiCellPolugon*
> > > > - visitTriangle
> > > > - *getVertexUniqueEdges*
> > > > - TriangleCoordinateVisitor
> > > > - *TriangleCircumcenterVisitor*
> > > > - *TriangleEdgeListVisitor*
> > > > - *TriangleVertexListVisitor*
> > > > - *isFrameVertex*
> > > > 4. TriangleVisitor(Interface)
> > > > Plz let me know if i am missing some method or class which is
> required
> > > > for VoronoiDiagramBuilder port.
> > > Again, looking is part of the work.
> > > You'll find out as you start porting if anything is missing.
> > > > Is it me or its very few work for a Gsoc Project?
> > > Don't forget the testcases for the C++ implementation,
> > > the C-API exposure and relative testcases and audit for
> > > memory leakage.
> > > After you've done, if you still have time it'd be nice to
> > > work on improving the performance of it :)
> > > --strk;
> > Vishal Tiwari
> > Undergraduate
> > Computer Science and Engineering
> > Lab for Spatial Informatics
> > IIIT-Hyderabad
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Vishal Tiwari
Undergraduate
IIIT-Hyderabad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130428/f5c7d75f/attachment.html>
