[geos-devel] [GEOS] #638: Recommend a static_cast around assert strings
GEOS geos-trac at osgeo.org
Mon Aug 5 13:49:20 PDT 2013
 Reporter:  goatbar     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.5.0
Component:  Default     |     Version:  3.3.8
 Severity:  Unassigned  |    Keywords:
Changes (by robe):
  * milestone:  => 3.5.0
Old description:
> I recommend that for all asserts with strings, that they be changed to
> wrap the string in a static_cast.  Not very exciting, but it makes the
> stricter compilers happier.
> e.g. in src/geom/util/GeometryEditor.cpp
> assert(!"SHOULD NEVER GET HERE");
> changes to
> assert(!static_cast<bool>("SHOULD NEVER GET HERE"));
New description:
 changes to
Comment:
 Not seeing this particular error on my mingw gcc 4.8 built with cmake.
 Though I do see this somewhat troubling notice
 In file included from
 c:/jenkins/geos/branches/3.4cmake/tests/xmltester/BufferResultMatcher.cpp:22:0:
 C:/jenkins/geos/branches/3.4cmake/include/geos/geom/BinaryOp.h: In
 instantiation of 'std::auto_ptr<geos::geom::Geometry>
 geos::geom::BinaryOp(const geos::geom::Geometry*, const
 geos::geom::Geometry*, BinOp) [with BinOp =
 geos::operation::overlay::overlayOp]':
 c:/jenkins/geos/branches/3.4cmake/tests/xmltester/BufferResultMatcher.cpp:80:58:
 required from here
 C:/jenkins/geos/branches/3.4cmake/include/geos/geom/BinaryOp.h:459:32:
 warning: overflow in implicit constant conversion [-Woverflow]
    long unsigned int maxScale = 1e16;
 I'd just assume avoid these changes in a micro release especially since we
 plan to release soon and sounds like a lot of changes would need to be
 made to accommodate this. Pushing to 3.5
Ticket URL: <http://trac.osgeo.org/geos/ticket/638#comment:4>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
