[geos-devel] [GEOS] #644: Can't build using cmake with tar ball
GEOS geos-trac at osgeo.org
Sat Aug 10 22:04:34 PDT 2013
 Reporter:  robe       |       Owner:  geos-devel@…
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  3.4.1
Component:  Default    |     Version:  3.4.0
 Severity:  Annoyance  |    Keywords:
 I verified I can build from the tagged SVN
 http://trac.osgeo.org/geos/browser/tags/3.4.0
 but tar ball I created fails with below.  It's almost as if the CMAKE
 config is relying on SVN.
 -- Found Subversion: C:/ming64gcc48/msys/bin/svn.exe (found version
 "1.6.17")
 CMake Error at
 c:/ming64gcc48/cmake-2.8.11-win32-x86/share/cmake-2.8/Modules/Fin
 dSubversion.cmake:83 (message):
   Command "C:/ming64gcc48/msys/bin/svn.exe info
   C:/ming64gcc48/projects/geos/geos-3.4.0" failed with output:
   svn: 'C:\ming64gcc48\projects\geos\geos-3.4.0' is not a working copy
 Call Stack (most recent call first):
   CMakeLists.txt:249 (Subversion_WC_INFO)
   CMakeLists.txt:257 (GET_SVN_REVISION)
 -- Generating revision header
 C:/ming64gcc48/projects/geos/geos-3.4.0/geos_svn_r
 evision.h
 Can't fetch local revision (neither .svn nor .git found)
 Not updating existing rev file at GEOS_SVN_REVISION
 -- Enable GEOS Unit Tests build - ON
 -- Enable GEOS XML Tester build - ON
 -- Enable GEOS large geometry tests build - ON
 -- CMake 2.8.11 successfully configured geos using MSYS Makefiles
 generator
 -- Configuring incomplete, errors occurred!
Ticket URL: <http://trac.osgeo.org/geos/ticket/644>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
