[geos-devel] GEOS 3.4.0 is out
Paragon Corporation
lr at pcorp.us
Sat Aug 10 22:15:45 PDT 2013
The GEOS development team is proud to release GEOS 3.4.0 which you can
download from: http://download.osgeo.org/geos/geos-3.4.0.tar.bz2
Svn: https://svn.osgeo.org/geos/tags/3.4.0
- New things:
- Delaunay Triangulation API (#487, #565, #570, #567)
- Interruptibility API (C and C++)
- CAPI: GEOSNode (#496) - PHP: Geometry->node
- GeometryPrecisionReducer class (#496, #526)
- BufferInputLineSimplifier header exposed (#548)
- New Centroid class supporting mixed geometry components (#612)
- io::Writer::reserve() method
- CAPI: GEOSNearestPoints
- Add --cclibs, --static-clibs and --static-cclibs to geos-config (#497)
- Early bail out of overlay exception if input is invalid
- C++ API changes:
- New noding::GeometryNoder class
- Added BufferOp::setSingleSided
- Signature of most functions taking a Label changed to take it
by reference rather than pointer.
- Signature of most functions taking an IntersectionMatrix changed
to take it by reference rather than pointer.
- GraphComponent::label is now a Label value (from a pointer)
- NodedSegmentString takes ownership of CoordinateSenuence now
- io::Writer's toString() returns by const ref, write() takes a const ref
- Unify prototypes of WKTReader and WKBReader constructor (#310)
- GeometryCollection::computeEnvelopInternal and
GeometryCollection::compareToSameClass are marked virtual (#478)
- Bug fixes / improvements
- A point interpolated from a line does not always intersect
the same line (#323)
- Port ConvexHull robustness fix from JTS-1.13 (#457)
- Improve Overlay robustness by reducing input precision on topology
exception and by refusing to accept unnoded output (#459)
- Improve Buffer robustness by reducing input precision on topology
exception (#605)
- Mismatch segment sides in OffsetCurveBuilder (#633 )
- Fixed Linear Referencing API to handle MultiLineStrings consistently
by always using the lowest possible index value, and by trimming
zero-length components from results (#323)
- Fixed CMake configuration to set correct SOVERSION (current - age)
- Fix EMPTY return from single-point lines and zero-length polygons (#612)
- CMakeLists.txt, tools/geos_svn_revision_cmake.h.in: Add
geos_svn_revision.h generator to CMake config (#643)
- Makefile.vc 'clean' step leaks obj files (#607)
Please test and report any issues.
Thanks,
Regina and rest of GEOS Development Team
