[geos-devel] [postgis-devel] GEOS 3.4.0 is out
Sandro Santilli
strk at keybit.net
Sun Aug 11 07:45:20 PDT 2013
On Sun, Aug 11, 2013 at 08:28:00AM -0400, Greg Troxel wrote:
> In trying to update the geos package on pkgsrc, I ran into a few things.
> One was DOS line endings, as others reported.
> The other was a surprisingly large change in the set of installed files,
> relative to what I expected from reading NEWS. Most of this diff should
> make sense to people that don't know pkgsrc details; the last line
> indicates that the new version installs an empty /usr/pkg/lib/geos
> directory.
Delaunay triangulation and interruptability are mentioned in the NEWS file,
everything is expected, except maybe the empty /usr/pkg/lib/geos which
I've no ideaabout.
> Also, make check fails complaining about testrunner, and reading README
> didn't explain that there was an additional test dependency. (This is
> probably not new in 3.4.0, but i thought I'd mention it.)
testrunner should be another case of DOS line endings.
Can you re-check with current 3.4 branch ?
--strk;
