[geos-devel] [postgis-devel] GEOS 3.4.0 is out
Greg Troxel
gdt at ir.bbn.com
Sun Aug 11 08:22:03 PDT 2013
Sandro Santilli <strk at keybit.net> writes:
>> The other was a surprisingly large change in the set of installed files,
>> relative to what I expected from reading NEWS. Most of this diff should
>> make sense to people that don't know pkgsrc details; the last line
>> indicates that the new version installs an empty /usr/pkg/lib/geos
>> directory.
> Delaunay triangulation and interruptability are mentioned in the NEWS file,
> everything is expected,
Thanks. I didn't mean to complain about NEWS as much as run the diff by
someone who has been paying attention. Indeed, I did see triangulation
files and Interrupt.h, and I didn't blink at those. It was more a
number of with withdrawn files. In particular the removal of
geos/platform.h jumped out at me as something I didn't expect.
> except maybe the empty /usr/pkg/lib/geos which I've no ideaabout.
That's probably a bug then; I'll see if it recurs with the imminent
eol-style=lf 3.4.1 tarball.
>> Also, make check fails complaining about testrunner, and reading README
>> didn't explain that there was an additional test dependency. (This is
>> probably not new in 3.4.0, but i thought I'd mention it.)
> testrunner should be another case of DOS line endings.
> Can you re-check with current 3.4 branch ?
I'll retry with the fixed release when it comes. I'm just barely able
delurk long enough to update the package.
Also:
I just noticed there is a new 3.4.0 tarball with a different hash. It
seems 3 people spoke up about that issue, including the person who deals
with openSUSE packages, and opinion was unanimous about not having two
different distfiles with the same name.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130811/92057aca/attachment.pgp>
