[geos-devel] test failures
Greg Troxel gdt at ir.bbn.com
Sat Aug 17 18:06:34 PDT 2013
With 3.4.1, I ran the tests on NetBSD 6, i386.  I got 3 failures. Are
these really "XFAIL" as some test driveres woudl call them, and known
bugs and not indicative that anything is worse on my platform than
anywhere else?
Runner: testrunner created
./tests/ticket/bug527.xml: case1: test1: union(A): failed.
	Description: Bogus noding http://trac.osgeo.org/geos/ticket/527
	Geometry A: LINESTRING (1725063.0000000000000000 4819121.0000000000000000, 1725064.1418388199526817 4819094.7020855704322457, 1725064.1365604400634766 4819094.7023506900295615, 1725064.1421036201063544 4819094.7022725204005837, 1725064.1365604300517589 4819094.7023506900295615, 1725063.0000000000000000 4819121.0000000000000000)
	Expected result: MULTILINESTRING ((1725063.0000000000000000 4819121.0000000000000000, 1725064.1418305400293320 4819094.7022763695567846), (1725064.1418305400293320 4819094.7022763695567846, 1725064.1418388199526817 4819094.7020855704322457, 1725064.1365604400634766 4819094.7023506900295615), (1725064.1365604400634766 4819094.7023506900295615, 1725064.1418305400293320 4819094.7022763695567846), (1725064.1418305400293320 4819094.7022763695567846, 1725064.1421036201063544 4819094.7022725204005837, 1725064.1418305400293320 4819094.7022763695567846), (1725064.1365604400634766 4819094.7023506900295615, 1725064.1365604300517589 4819094.7023506900295615, 1725063.0000000000000000 4819121.0000000000000000))
	Obtained result: MULTILINESTRING ((1725063.0000000000000000 4819121.0000000000000000, 1725064.1418305360712111 4819094.7022763527929783), (1725064.1418305360712111 4819094.7022763527929783, 1725064.1418388248421252 4819094.7020855713635683, 1725064.1365604375023395 4819094.7023506956174970), (1725064.1365604375023395 4819094.7023506956174970, 1725064.1418305360712111 4819094.7022763527929783), (1725064.1418305360712111 4819094.7022763527929783, 1725064.1421036231331527 4819094.7022725110873580), (1725064.1365604375023395 4819094.7023506956174970, 1725063.0000000000000000 4819121.0000000000000000))
./tests/ticket/bug586.xml: case1: test1: intersection(A, B): failed.
	Description: http://trac.osgeo.org/geos/ticket/586
	Geometry A: MULTIPOLYGON (((-95.1504641180981139 52.8191254120286615, -88.9894328511470718 56.8474385213783151, -74.3418742981712199 44.9689592856699392, -78.8683109745671942 42.8636399012997131, -82.9538024908096503 41.9896599491809752, -95.1325515008582130 49.4329166068978338, -95.1504641180981139 52.8191254120286615)))
	Geometry B: LINESTRING (-82.3712000000000018 42.7280400000000000, -82.3712600000000066 42.7279399999999967, -82.3711500000000001 42.7280700000000024, -82.3712000000000018 42.7279199999999975, -82.3714099999999974 42.7280700000000024, -82.3711799999999954 42.7279300000000006, -82.3712600000000066 42.7280799999999985, -82.3712199999999939 42.7279800000000023, -82.3711299999999937 42.7281300000000002, -82.3712400000000002 42.7281400000000033, -82.3712000000000018 42.7279800000000023, -82.3713300000000004 42.7280900000000017, -82.3711799999999954 42.7279800000000023, -82.3712799999999987 42.7280599999999993, -82.3711299999999937 42.7281400000000033, -82.3712600000000066 42.7280999999999977, -82.3711299999999937 42.7279399999999967, -82.3712799999999987 42.7280900000000017, -82.3712000000000018 42.7279499999999999, -82.3710899999999953 42.7280900000000017, -82.3712199999999939 42.7280599999999993, -82.3711799999999954 42.7278999999999982, -82.3711100000000016 42.7280200000000008, -82.3712600000000066 42.7280900000000017, -82.3711299999999937 42.7279100000000014, -82.3712199999999939 42.7280000000000015)
	Expected result: MULTILINESTRING ((-82.3711455223880051 42.7279591044780034, -82.3711100000000016 42.7280200000000008, -82.3711356097559957 42.7280319512199966), (-82.3711468421050057 42.7279568421050016, -82.3711299999999937 42.7279399999999967, -82.3711455223880051 42.7279591044780034), (-82.3711550877190035 42.7281322807019990, -82.3711299999999937 42.7281400000000033, -82.3711460194169973 42.7281314563109973), (-82.3711578947369958 42.7279378947370034, -82.3711299999999937 42.7279100000000014, -82.3711544326239959 42.7279438297870016), (-82.3711642857140021 42.7280728571429975, -82.3710899999999953 42.7280900000000017, -82.3711356097559957 42.7280319512199966), (-82.3711642857140021 42.7280728571429975, -82.3711299999999937 42.7281300000000002, -82.3711460194169973 42.7281314563109973), (-82.3711690073530036 42.7280475367649970, -82.3711500000000001 42.7280700000000024, -82.3711590384619967 42.7280428846150002), (-82.3711888461539985 42.7279353846150016, -82.3711799999999954 42.7278999999999982, -82.3711578947369958 42.7279378947370034), (-82.3711902564100029 42.7279492307689992, -82.3711799999999954 42.7279300000000006, -82.3711888461539985 42.7279353846150016), (-82.3712166666669958 42.7280466666669980, -82.3712199999999939 42.7280599999999993, -82.3712037500000065 42.7280637499999969), (-82.3712185365850047 42.7279824390239966, -82.3712000000000018 42.7279499999999999, -82.3711944404330012 42.7279570758120002), (-82.3712219753089983 42.7279849382720016, -82.3712199999999939 42.7279800000000023, -82.3712185365850047 42.7279824390239966), (-82.3712321428569965 42.7281085714289972, -82.3712400000000002 42.7281400000000033, -82.3711550877190035 42.7281322807019990), (-82.3712439344260048 42.7280268852460026, -82.3713300000000004 42.7280900000000017, -82.3712331914889972 42.7280080851059978), (-82.3712469127519995 42.7280838926170006, -82.3712600000000066 42.7280999999999977, -82.3712321428569965 42.7281085714289972), (-82.3712479452049990 42.7279542465750026, -82.3712000000000018 42.7279199999999975, -82.3711938554220069 42.7279384337349981), (-82.3712499197859955 42.7280760427809980, -82.3712600000000066 42.7280900000000017, -82.3712469127519995 42.7280838926170006), (-82.3712503999999939 42.7279559999999989, -82.3712600000000066 42.7279399999999967, -82.3712479452049990 42.7279542465750026), (-82.3712503999999939 42.7279559999999989, -82.3714099999999974 42.7280700000000024, -82.3712429936310002 42.7279683439490015), (-82.3712569230769986 42.7280723076920026, -82.3712600000000066 42.7280799999999985, -82.3712561245669974 42.7280727335639980), (-82.3712668613139982 42.7280670072990034, -82.3712799999999987 42.7280900000000017, -82.3712604347829966 42.7280704347829996), (-82.3712668613139982 42.7280670072990034, -82.3712799999999987 42.7280599999999993, -82.3712484210529965 42.7280347368419982), (-82.3711468421050057 42.7279568421050016, -82.3711455223880051 42.7279591044780034), (-82.3711544326239959 42.7279438297870016, -82.3711468421050057 42.7279568421050016), (-82.3711550877190035 42.7281322807019990, -82.3711460194169973 42.7281314563109973), (-82.3711578947369958 42.7279378947370034, -82.3711544326239959 42.7279438297870016), (-82.3711590384619967 42.7280428846150002, -82.3711356097559957 42.7280319512199966), (-82.3711690073530036 42.7280475367649970, -82.3711590384619967 42.7280428846150002), (-82.3711695810060007 42.7279887150840025, -82.3711356097559957 42.7280319512199966), (-82.3711695810060007 42.7279887150840025, -82.3711455223880051 42.7279591044780034), (-82.3711736000000059 42.7279836000000017, -82.3711468421050057 42.7279568421050016), (-82.3711736000000059 42.7279836000000017, -82.3711695810060007 42.7279887150840025), (-82.3711749090909962 42.7279952727270000, -82.3711590384619967 42.7280428846150002), (-82.3711749090909962 42.7279952727270000, -82.3711695810060007 42.7279887150840025), (-82.3711771874999954 42.7280513541670004, -82.3711642857140021 42.7280728571429975), (-82.3711771874999954 42.7280513541670004, -82.3711690073530036 42.7280475367649970), (-82.3711775000000017 42.7279874999999976, -82.3711736000000059 42.7279836000000017), (-82.3711775000000017 42.7279874999999976, -82.3711749090909962 42.7279952727270000), (-82.3711785789469957 42.7279772631580030, -82.3711544326239959 42.7279438297870016), (-82.3711785789469957 42.7279772631580030, -82.3711736000000059 42.7279836000000017), (-82.3711799999999954 42.7279800000000023, -82.3711775000000017 42.7279874999999976), (-82.3711801754389938 42.7279794736840017, -82.3711785789469957 42.7279772631580030), (-82.3711801754389938 42.7279794736840017, -82.3711799999999954 42.7279800000000023), (-82.3711811811020027 42.7279808661419978, -82.3711799999999954 42.7279800000000023), (-82.3711811811020027 42.7279808661419978, -82.3711801754389938 42.7279794736840017), (-82.3711813157890020 42.7279810526320034, -82.3711799999999954 42.7279800000000023), (-82.3711813157890020 42.7279810526320034, -82.3711811811020027 42.7279808661419978), (-82.3711826315790034 42.7279721052629995, -82.3711785789469957 42.7279772631580030), (-82.3711826315790034 42.7279721052629995, -82.3711801754389938 42.7279794736840017), (-82.3711849999999970 42.7279649999999975, -82.3711578947369958 42.7279378947370034), (-82.3711849999999970 42.7279649999999975, -82.3711826315790034 42.7279721052629995), (-82.3711868000000038 42.7279667999999972, -82.3711826315790034 42.7279721052629995), (-82.3711868000000038 42.7279667999999972, -82.3711849999999970 42.7279649999999975), (-82.3711902564100029 42.7279492307689992, -82.3711849999999970 42.7279649999999975), (-82.3711914285709952 42.7279457142860011, -82.3711888461539985 42.7279353846150016), (-82.3711914285709952 42.7279457142860011, -82.3711902564100029 42.7279492307689992), (-82.3711936811589993 42.7280183768120025, -82.3711690073530036 42.7280475367649970), (-82.3711936811589993 42.7280183768120025, -82.3711749090909962 42.7279952727270000), (-82.3711938554220069 42.7279384337349981, -82.3711888461539985 42.7279353846150016), (-82.3711938554220069 42.7279384337349981, -82.3711914285709952 42.7279457142860011), (-82.3711941176469935 42.7279564705879977, -82.3711902564100029 42.7279492307689992), (-82.3711941176469935 42.7279564705879977, -82.3711914285709952 42.7279457142860011), (-82.3711943103450039 42.7279572413790021, -82.3711868000000038 42.7279667999999972), (-82.3711943103450039 42.7279572413790021, -82.3711941176469935 42.7279564705879977), (-82.3711944404330012 42.7279570758120002, -82.3711941176469935 42.7279564705879977), (-82.3711944404330012 42.7279570758120002, -82.3711943103450039 42.7279572413790021), (-82.3711955752209946 42.7280207079650012, -82.3711771874999954 42.7280513541670004), (-82.3711955752209946 42.7280207079650012, -82.3711936811589993 42.7280183768120025), (-82.3712000000000018 42.7279800000000023, -82.3711868000000038 42.7279667999999972), (-82.3712000000000018 42.7279800000000023, -82.3711943103450039 42.7279572413790021), (-82.3712004166669942 42.7280104166669972, -82.3711775000000017 42.7279874999999976), (-82.3712004166669942 42.7280104166669972, -82.3711936811589993 42.7280183768120025), (-82.3712012499999986 42.7280112500000016, -82.3711955752209946 42.7280207079650012), (-82.3712012499999986 42.7280112500000016, -82.3712004166669942 42.7280104166669972), (-82.3712015531340001 42.7280090735689981, -82.3711813157890020 42.7279810526320034), (-82.3712015531340001 42.7280090735689981, -82.3712004166669942 42.7280104166669972), (-82.3712021008399944 42.7280098319330008, -82.3712012499999986 42.7280112500000016), (-82.3712021008399944 42.7280098319330008, -82.3712015531340001 42.7280090735689981), (-82.3712037500000065 42.7280637499999969, -82.3711642857140021 42.7280728571429975), (-82.3712037500000065 42.7280637499999969, -82.3711771874999954 42.7280513541670004), (-82.3712044897959998 42.7279979591840018, -82.3711811811020027 42.7279808661419978), (-82.3712044897959998 42.7279979591840018, -82.3712000000000018 42.7279800000000023), (-82.3712047787609976 42.7280320353980017, -82.3711955752209946 42.7280207079650012), (-82.3712047787609976 42.7280320353980017, -82.3712000000000018 42.7280400000000000), (-82.3712050000000033 42.7280050000000031, -82.3712015531340001 42.7280090735689981), (-82.3712050000000033 42.7280050000000031, -82.3712021008399944 42.7280098319330008), (-82.3712050000000033 42.7280000000000015, -82.3711813157890020 42.7279810526320034), (-82.3712050000000033 42.7280000000000015, -82.3712044897959998 42.7279979591840018), (-82.3712058823529958 42.7280035294119998, -82.3712050000000033 42.7280050000000031), (-82.3712058823529958 42.7280035294119998, -82.3712050000000033 42.7280000000000015), (-82.3712059649119936 42.7280038596490002, -82.3712050000000033 42.7280050000000031), (-82.3712059649119936 42.7280038596490002, -82.3712058823529958 42.7280035294119998), (-82.3712070270269976 42.7280016216219991, -82.3712050000000033 42.7280000000000015), (-82.3712070270269976 42.7280016216219991, -82.3712058823529958 42.7280035294119998), (-82.3712075229360039 42.7280020183490024, -82.3712059649119936 42.7280038596490002), (-82.3712075229360039 42.7280020183490024, -82.3712070270269976 42.7280016216219991), (-82.3712077777779967 42.7280003703699975, -82.3712044897959998 42.7279979591840018), (-82.3712077777779967 42.7280003703699975, -82.3712070270269976 42.7280016216219991), (-82.3712079999999958 42.7280179999999987, -82.3712012499999986 42.7280112500000016), (-82.3712079999999958 42.7280179999999987, -82.3712021008399944 42.7280098319330008), (-82.3712084810129994 42.7280008860760034, -82.3712075229360039 42.7280020183490024), (-82.3712084810129994 42.7280008860760034, -82.3712077777779967 42.7280003703699975), (-82.3712100000000049 42.7280200000000008, -82.3712059649119936 42.7280038596490002), (-82.3712100000000049 42.7280200000000008, -82.3712079999999958 42.7280179999999987), (-82.3712102941180007 42.7280211764710032, -82.3712079999999958 42.7280179999999987), (-82.3712102941180007 42.7280211764710032, -82.3712100000000049 42.7280200000000008), (-82.3712105882350016 42.7280223529409966, -82.3712047787609976 42.7280320353980017), (-82.3712105882350016 42.7280223529409966, -82.3712102941180007 42.7280211764710032), (-82.3712108403360048 42.7280219327729966, -82.3712102941180007 42.7280211764710032), (-82.3712108403360048 42.7280219327729966, -82.3712105882350016 42.7280223529409966), (-82.3712112500000018 42.7280212499999976, -82.3712100000000049 42.7280200000000008), (-82.3712112500000018 42.7280212499999976, -82.3712108403360048 42.7280219327729966), (-82.3712121495329939 42.7279902803740015, -82.3711944404330012 42.7279570758120002), (-82.3712121495329939 42.7279902803740015, -82.3712000000000018 42.7279800000000023), (-82.3712124999999986 42.7279924999999992, -82.3712000000000018 42.7279800000000023), (-82.3712124999999986 42.7279924999999992, -82.3712077777779967 42.7280003703699975), (-82.3712129411759975 42.7279917647059975, -82.3712121495329939 42.7279902803740015), (-82.3712129411759975 42.7279917647059975, -82.3712124999999986 42.7279924999999992), (-82.3712132653059967 42.7279912244899975, -82.3712121495329939 42.7279902803740015), (-82.3712132653059967 42.7279912244899975, -82.3712129411759975 42.7279917647059975), (-82.3712141666670021 42.7279941666670027, -82.3712084810129994 42.7280008860760034), (-82.3712141666670021 42.7279941666670027, -82.3712124999999986 42.7279924999999992), (-82.3712142007429975 42.7279941263940017, -82.3712129411759975 42.7279917647059975), (-82.3712142007429975 42.7279941263940017, -82.3712141666670021 42.7279941666670027), (-82.3712142857140037 42.7279942857139972, -82.3712141666670021 42.7279941666670027), (-82.3712142857140037 42.7279942857139972, -82.3712142007429975 42.7279941263940017), (-82.3712152413790051 42.7279928965520028, -82.3712132653059967 42.7279912244899975), (-82.3712152413790051 42.7279928965520028, -82.3712142007429975 42.7279941263940017), (-82.3712166666669958 42.7280466666669980, -82.3712047787609976 42.7280320353980017), (-82.3712166666669958 42.7280466666669980, -82.3712105882350016 42.7280223529409966), (-82.3712178378380031 42.7280102702699978, -82.3712075229360039 42.7280020183490024), (-82.3712178378380031 42.7280102702699978, -82.3712112500000018 42.7280212499999976), (-82.3712185365850047 42.7279824390239966, -82.3712132653059967 42.7279912244899975), (-82.3712188888890040 42.7280085185189975, -82.3712084810129994 42.7280008860760034), (-82.3712188888890040 42.7280085185189975, -82.3712178378380031 42.7280102702699978), (-82.3712199999999939 42.7280000000000015, -82.3712142857140037 42.7279942857139972), (-82.3712204705879998 42.7280058823530027, -82.3712142857140037 42.7279942857139972), (-82.3712204705879998 42.7280058823530027, -82.3712188888890040 42.7280085185189975), (-82.3712207751940042 42.7279863565889997, -82.3712152413790051 42.7279928965520028), (-82.3712207751940042 42.7279863565889997, -82.3712185365850047 42.7279824390239966), (-82.3712219753089983 42.7279849382720016, -82.3712207751940042 42.7279863565889997), (-82.3712232075470041 42.7280728301889994, -82.3712037500000065 42.7280637499999969), (-82.3712232075470041 42.7280728301889994, -82.3712166666669958 42.7280466666669980), (-82.3712237956199971 42.7280121167880012, -82.3712188888890040 42.7280085185189975), (-82.3712237956199971 42.7280121167880012, -82.3712204705879998 42.7280058823530027), (-82.3712238775510031 42.7280002040820008, -82.3712152413790051 42.7279928965520028), (-82.3712238775510031 42.7280002040820008, -82.3712204705879998 42.7280058823530027), (-82.3712263414630002 42.7279960975609967, -82.3712207751940042 42.7279863565889997), (-82.3712263414630002 42.7279960975609967, -82.3712238775510031 42.7280002040820008), (-82.3712263999999976 42.7279959999999974, -82.3712219753089983 42.7279849382720016), (-82.3712263999999976 42.7279959999999974, -82.3712263414630002 42.7279960975609967), (-82.3712265116279951 42.7280172093020028, -82.3712178378380031 42.7280102702699978), (-82.3712265116279951 42.7280172093020028, -82.3712237956199971 42.7280121167880012), (-82.3712266666669990 42.7279966666670035, -82.3712263414630002 42.7279960975609967), (-82.3712266666669990 42.7279966666670035, -82.3712263999999976 42.7279959999999974), (-82.3712270588240045 42.7280882352940026, -82.3711460194169973 42.7281314563109973), (-82.3712270588240045 42.7280882352940026, -82.3712232075470041 42.7280728301889994), (-82.3712302325580055 42.7280055813950028, -82.3712238775510031 42.7280002040820008), (-82.3712302325580055 42.7280055813950028, -82.3712266666669990 42.7279966666670035), (-82.3712321428569965 42.7281085714289972, -82.3711550877190035 42.7281322807019990), (-82.3712321428569965 42.7281085714289972, -82.3712270588240045 42.7280882352940026), (-82.3712331914889972 42.7280080851059978, -82.3712266666669990 42.7279966666670035), (-82.3712331914889972 42.7280080851059978, -82.3712302325580055 42.7280055813950028), (-82.3712366037739940 42.7280215094340008, -82.3712237956199971 42.7280121167880012), (-82.3712366037739940 42.7280215094340008, -82.3712302325580055 42.7280055813950028), (-82.3712383885209931 42.7279655408390013, -82.3711938554220069 42.7279384337349981), (-82.3712383885209931 42.7279655408390013, -82.3712219753089983 42.7279849382720016), (-82.3712388235289978 42.7280270588239972, -82.3712265116279951 42.7280172093020028), (-82.3712388235289978 42.7280270588239972, -82.3712366037739940 42.7280215094340008), (-82.3712406666670063 42.7280809777779993, -82.3712232075470041 42.7280728301889994), (-82.3712406666670063 42.7280809777779993, -82.3712270588240045 42.7280882352940026), (-82.3712429936310002 42.7279683439490015, -82.3712263999999976 42.7279959999999974), (-82.3712429936310002 42.7279683439490015, -82.3712383885209931 42.7279655408390013), (-82.3712433720930051 42.7280795348840030, -82.3712166666669958 42.7280466666669980), (-82.3712433720930051 42.7280795348840030, -82.3712406666670063 42.7280809777779993), (-82.3712439344260048 42.7280268852460026, -82.3712331914889972 42.7280080851059978), (-82.3712439344260048 42.7280268852460026, -82.3712366037739940 42.7280215094340008), (-82.3712469127519995 42.7280838926170006, -82.3712406666670063 42.7280809777779993), (-82.3712469127519995 42.7280838926170006, -82.3712433720930051 42.7280795348840030), (-82.3712479452049990 42.7279542465750026, -82.3712383885209931 42.7279655408390013), (-82.3712484210529965 42.7280347368419982, -82.3712388235289978 42.7280270588239972), (-82.3712484210529965 42.7280347368419982, -82.3712439344260048 42.7280268852460026), (-82.3712485714290068 42.7280585714290027, -82.3712112500000018 42.7280212499999976), (-82.3712485714290068 42.7280585714290027, -82.3712265116279951 42.7280172093020028), (-82.3712499197859955 42.7280760427809980, -82.3712108403360048 42.7280219327729966), (-82.3712499197859955 42.7280760427809980, -82.3712433720930051 42.7280795348840030), (-82.3712503999999939 42.7279559999999989, -82.3712429936310002 42.7279683439490015), (-82.3712503999999939 42.7279559999999989, -82.3712479452049990 42.7279542465750026), (-82.3712533333330015 42.7280633333329973, -82.3712388235289978 42.7280270588239972), (-82.3712533333330015 42.7280633333329973, -82.3712485714290068 42.7280585714290027), (-82.3712561245669974 42.7280727335639980, -82.3712485714290068 42.7280585714290027), (-82.3712561245669974 42.7280727335639980, -82.3712499197859955 42.7280760427809980), (-82.3712569230769986 42.7280723076920026, -82.3712533333330015 42.7280633333329973), (-82.3712569230769986 42.7280723076920026, -82.3712561245669974 42.7280727335639980), (-82.3712604347829966 42.7280704347829996, -82.3712533333330015 42.7280633333329973), (-82.3712604347829966 42.7280704347829996, -82.3712569230769986 42.7280723076920026), (-82.3712668613139982 42.7280670072990034, -82.3712484210529965 42.7280347368419982), (-82.3712668613139982 42.7280670072990034, -82.3712604347829966 42.7280704347829996))
	Obtained result: MULTILINESTRING ((-82.3711455351742785 42.7279590866258516, -82.3711100052172753 42.7280199951235957, -82.3711356165886457 42.7280319393358781), (-82.3711468390259256 42.7279568281685584, -82.3711300053700057 42.7279399945126457, -82.3711455351742785 42.7279590866258516), (-82.3711550579478171 42.7281322893455382, -82.3711300053700057 42.7281399960400137, -82.3711460008355800 42.7281314511551997), (-82.3711578984817407 42.7279378990368102, -82.3711300053700057 42.7279100059250752, -82.3711544293050650 42.7279438362183512), (-82.3711642780415190 42.7280728476808846, -82.3710900050645307 42.7280900072997056, -82.3711356165886457 42.7280319393358781), (-82.3711642780415190 42.7280728476808846, -82.3711300053700057 42.7281300076051807, -82.3711460008355800 42.7281314511551997), (-82.3711690045036846 42.7280475389893581, -82.3711500055227361 42.7280700071469681, -82.3711590393519231 42.7280428823763785), (-82.3711888416749787 42.7279353844658019, -82.3711799941103209 42.7278999942071707, -82.3711578984817407 42.7279378990368102), (-82.3711902619419334 42.7279492378894048, -82.3711799941103209 42.7279300060778127, -82.3711888416749787 42.7279353844658019), (-82.3712185275826982 42.7279824395399359, -82.3711999942630513 42.7279500062305502, -82.3711944296105401 42.7279570842822736), (-82.3712219734763096 42.7279849308278799, -82.3712199944157959 42.7279799948181207, -82.3712185275826982 42.7279824395399359), (-82.3712321481756646 42.7281085639024170, -82.3712399945685263 42.7281399960400137, -82.3711550579478171 42.7281322893455382), (-82.3712439294064893 42.7280268636277327, -82.3713300068973808 42.7280900072997056, -82.3712331726305109 42.7280080741943706), (-82.3712469329218635 42.7280839071367069, -82.3712599947212567 42.7280999957345458, -82.3712321481756646 42.7281085639024170), (-82.3712479340936596 42.7279542437483570, -82.3711999942630513 42.7279199943599082, -82.3711938475339167 42.7279384345472977), (-82.3712499131541733 42.7280760374607738, -82.3712599947212567 42.7280900072997056, -82.3712469329218635 42.7280839071367069), (-82.3712504020985250 42.7279559899782271, -82.3712599947212567 42.7279399945126457, -82.3712479340936596 42.7279542437483570), (-82.3712504020985250 42.7279559899782271, -82.3714100075083167 42.7280700071469681, -82.3712429748008361 42.7279683532856751), (-82.3712569213567036 42.7280723121703900, -82.3712599947212567 42.7280799955818082, -82.3712561297324868 42.7280727312655628), (-82.3712668399423364 42.7280670036316010, -82.3712799948740013 42.7280900072997056, -82.3712604138164295 42.7280704262421409), (-82.3712668399423364 42.7280670036316010, -82.3712799948740013 42.7280599954290707, -82.3712483997549469 42.7280347333036659), (-82.3711468390259256 42.7279568281685584, -82.3711455351742785 42.7279590866258516), (-82.3711544293050650 42.7279438362183512, -82.3711468390259256 42.7279568281685584), (-82.3711550579478171 42.7281322893455382, -82.3711460008355800 42.7281314511551997), (-82.3711578984817407 42.7279378990368102, -82.3711544293050650 42.7279438362183512), (-82.3711590393519231 42.7280428823763785, -82.3711356165886457 42.7280319393358781), (-82.3711690045036846 42.7280475389893581, -82.3711590393519231 42.7280428823763785), (-82.3711695865803080 42.7279887026843852, -82.3711356165886457 42.7280319393358781), (-82.3711695865803080 42.7279887026843852, -82.3711455351742785 42.7279590866258516), (-82.3711735912674783 42.7279836036931755, -82.3711468390259256 42.7279568281685584), (-82.3711735912674783 42.7279836036931755, -82.3711695865803080 42.7279887026843852), (-82.3711749184021755 42.7279952685086855, -82.3711590393519231 42.7280428823763785), (-82.3711749184021755 42.7279952685086855, -82.3711695865803080 42.7279887026843852), (-82.3711771768594616 42.7280513574119993, -82.3711642780415190 42.7280728476808846), (-82.3711771768594616 42.7280513574119993, -82.3711690045036846 42.7280475389893581), (-82.3711775028223769 42.7279874919650169, -82.3711735912674783 42.7279836036931755), (-82.3711775028223769 42.7279874919650169, -82.3711749184021755 42.7279952685086855), (-82.3711785738433520 42.7279772706995260, -82.3711544293050650 42.7279438362183512), (-82.3711785738433520 42.7279772706995260, -82.3711735912674783 42.7279836036931755), (-82.3711799941103209 42.7279799948181207, -82.3711775028223769 42.7279874919650169), (-82.3711801803748358 42.7279794825906905, -82.3711785738433520 42.7279772706995260), (-82.3711801803748358 42.7279794825906905, -82.3711799941103209 42.7279799948181207), (-82.3711811815466319 42.7279808562915235, -82.3711799941103209 42.7279799948181207), (-82.3711811815466319 42.7279808562915235, -82.3711801803748358 42.7279794825906905), (-82.3711812979619538 42.7279810425560385, -82.3711799941103209 42.7279799948181207), (-82.3711812979619538 42.7279810425560385, -82.3711811815466319 42.7279808562915235), (-82.3711826250966510 42.7279721018591232, -82.3711785738433520 42.7279772706995260), (-82.3711826250966510 42.7279721018591232, -82.3711801803748358 42.7279794825906905), (-82.3711849999692731 42.7279650005243354, -82.3711578984817407 42.7279378990368102), (-82.3711849999692731 42.7279650005243354, -82.3711826250966510 42.7279721018591232), (-82.3711867927652577 42.7279667933203342, -82.3711826250966510 42.7279721018591232), (-82.3711867927652577 42.7279667933203342, -82.3711849999692731 42.7279650005243354), (-82.3711902619419334 42.7279492378894048, -82.3711849999692731 42.7279650005243354), (-82.3711914260951801 42.7279457221466075, -82.3711888416749787 42.7279353844658019), (-82.3711914260951801 42.7279457221466075, -82.3711902619419334 42.7279492378894048), (-82.3711936845524662 42.7280183653090546, -82.3711690045036846 42.7280475389893581), (-82.3711936845524662 42.7280183653090546, -82.3711749184021755 42.7279952685086855), (-82.3711938475339167 42.7279384345472977, -82.3711888416749787 42.7279353844658019), (-82.3711938475339167 42.7279384345472977, -82.3711914260951801 42.7279457221466075), (-82.3711941269307033 42.7279564789225859, -82.3711902619419334 42.7279492378894048), (-82.3711941269307033 42.7279564789225859, -82.3711914260951801 42.7279457221466075), (-82.3711943131952182 42.7279572472637241, -82.3711867927652577 42.7279667933203342), (-82.3711943131952182 42.7279572472637241, -82.3711941269307033 42.7279564789225859), (-82.3711944296105401 42.7279570842822736, -82.3711941269307033 42.7279564789225859), (-82.3711944296105401 42.7279570842822736, -82.3711943131952182 42.7279572472637241), (-82.3711955704807224 42.7280206936155409, -82.3711771768594616 42.7280513574119993), (-82.3711955704807224 42.7280206936155409, -82.3711936845524662 42.7280183653090546), (-82.3711999942630513 42.7279799948181207, -82.3711867927652577 42.7279667933203342), (-82.3711999942630513 42.7279799948181207, -82.3711943131952182 42.7279572472637241), (-82.3712004133582241 42.7280104257839284, -82.3711775028223769 42.7279874919650169), (-82.3712004133582241 42.7280104257839284, -82.3711936845524662 42.7280183653090546), (-82.3712012515485554 42.7280112406911954, -82.3711955704807224 42.7280206936155409), (-82.3712012515485554 42.7280112406911954, -82.3712004133582241 42.7280104257839284), (-82.3712015542284064 42.7280090753661668, -82.3711812979619538 42.7279810425560385), (-82.3712015542284064 42.7280090753661668, -82.3712004133582241 42.7280104257839284), (-82.3712020897388868 42.7280098437073050, -82.3712012515485554 42.7280112406911954), (-82.3712020897388868 42.7280098437073050, -82.3712015542284064 42.7280090753661668), (-82.3712037428364994 42.7280637440025188, -82.3711642780415190 42.7280728476808846), (-82.3712037428364994 42.7280637440025188, -82.3711771768594616 42.7280513574119993), (-82.3712044878945733 42.7279979460611514, -82.3711811815466319 42.7279808562915235), (-82.3712044878945733 42.7279979460611514, -82.3711999942630513 42.7279799948181207), (-82.3712047672913599 42.7280320324681426, -82.3711955704807224 42.7280206936155409), (-82.3712047672913599 42.7280320324681426, -82.3711999942630513 42.7280399952763332), (-82.3712049768389392 42.7280050241128748, -82.3712015542284064 42.7280090753661668), (-82.3712049768389392 42.7280050241128748, -82.3712020897388868 42.7280098437073050), (-82.3712050001220035 42.7279999949708582, -82.3711812979619538 42.7279810425560385), (-82.3712050001220035 42.7279999949708582, -82.3712044878945733 42.7279979460611514), (-82.3712058848784636 42.7280035339967199, -82.3712049768389392 42.7280050241128748), (-82.3712058848784636 42.7280035339967199, -82.3712050001220035 42.7279999949708582), (-82.3712059547276567 42.7280038599596281, -82.3712049768389392 42.7280050241128748), (-82.3712059547276567 42.7280038599596281, -82.3712058848784636 42.7280035339967199), (-82.3712070257486459 42.7280016247853993, -82.3712050001220035 42.7279999949708582), (-82.3712070257486459 42.7280016247853993, -82.3712058848784636 42.7280035339967199), (-82.3712075146930118 42.7280020205975006, -82.3712059547276567 42.7280038599596281), (-82.3712075146930118 42.7280020205975006, -82.3712070257486459 42.7280016247853993), (-82.3712077708067199 42.7280003674998952, -82.3712044878945733 42.7279979460611514), (-82.3712077708067199 42.7280003674998952, -82.3712070257486459 42.7280016247853993), (-82.3712079803543133 42.7280179927800177, -82.3712012515485554 42.7280112406911954), (-82.3712079803543133 42.7280179927800177, -82.3712020897388868 42.7280098437073050), (-82.3712084925817294 42.7280008797273254, -82.3712075146930118 42.7280020205975006), (-82.3712084925817294 42.7280008797273254, -82.3712077708067199 42.7280003674998952), (-82.3712100059809558 42.7280199951235957, -82.3712059547276567 42.7280038599596281), (-82.3712100059809558 42.7280199951235957, -82.3712079803543133 42.7280179927800177), (-82.3712102853777282 42.7280211825599068, -82.3712079803543133 42.7280179927800177), (-82.3712102853777282 42.7280211825599068, -82.3712100059809558 42.7280199951235957), (-82.3712105880575791 42.7280223467131464, -82.3712047672913599 42.7280320324681426), (-82.3712105880575791 42.7280223467131464, -82.3712102853777282 42.7280211825599068), (-82.3712108441712871 42.7280219276179807, -82.3712102853777282 42.7280211825599068), (-82.3712108441712871 42.7280219276179807, -82.3712105880575791 42.7280223467131464), (-82.3712112399833956 42.7280212524090999, -82.3712100059809558 42.7280199951235957), (-82.3712112399833956 42.7280212524090999, -82.3712108441712871 42.7280219276179807), (-82.3712121480229200 42.7279902626497332, -82.3711944296105401 42.7279570842822736), (-82.3712121480229200 42.7279902626497332, -82.3711999942630513 42.7279799948181207), (-82.3712124972688997 42.7279924978239620, -82.3711999942630513 42.7279799948181207), (-82.3712124972688997 42.7279924978239620, -82.3712077708067199 42.7280003674998952), (-82.3712129396471227 42.7279917527658881, -82.3712121480229200 42.7279902626497332), (-82.3712129396471227 42.7279917527658881, -82.3712124972688997 42.7279924978239620), (-82.3712132656100380 42.7279912172553935, -82.3712121480229200 42.7279902626497332), (-82.3712132656100380 42.7279912172553935, -82.3712129396471227 42.7279917527658881), (-82.3712141736495624 42.7279941742046390, -82.3712084925817294 42.7280008797273254), (-82.3712141736495624 42.7279941742046390, -82.3712124972688997 42.7279924978239620), (-82.3712141969326268 42.7279941276385102, -82.3712129396471227 42.7279917527658881), (-82.3712141969326268 42.7279941276385102, -82.3712141736495624 42.7279941742046390), (-82.3712142667818341 42.7279942673368964, -82.3712141736495624 42.7279941742046390), (-82.3712142667818341 42.7279942673368964, -82.3712141969326268 42.7279941276385102), (-82.3712152446705517 42.7279928936360704, -82.3712132656100380 42.7279912172553935), (-82.3712152446705517 42.7279928936360704, -82.3712141969326268 42.7279941276385102), (-82.3712166649375064 42.7280466542328909, -82.3712047672913599 42.7280320324681426), (-82.3712166649375064 42.7280466542328909, -82.3712105880575791 42.7280223467131464), (-82.3712178290907531 42.7280102628024707, -82.3712075146930118 42.7280020205975006), (-82.3712178290907531 42.7280102628024707, -82.3712112399833956 42.7280212524090999), (-82.3712185275826982 42.7279824395399359, -82.3712132656100380 42.7279912172553935), (-82.3712188768286779 42.7280085165726078, -82.3712084925817294 42.7280008797273254), (-82.3712188768286779 42.7280085165726078, -82.3712178290907531 42.7280102628024707), (-82.3712199944157959 42.7280599954290707, -82.3712037428364994 42.7280637440025188), (-82.3712199944157959 42.7280599954290707, -82.3712166649375064 42.7280466542328909), (-82.3712199944157959 42.7279999949708582, -82.3712142667818341 42.7279942673368964), (-82.3712204600770832 42.7280058855862706, -82.3712142667818341 42.7279942673368964), (-82.3712204600770832 42.7280058855862706, -82.3712188768286779 42.7280085165726078), (-82.3712207627569342 42.7279863510948346, -82.3712152446705517 42.7279928936360704), (-82.3712207627569342 42.7279863510948346, -82.3712185275826982 42.7279824395399359), (-82.3712219734763096 42.7279849308278799, -82.3712207627569342 42.7279863510948346), (-82.3712232074787494 42.7280728243978203, -82.3712037428364994 42.7280637440025188), (-82.3712232074787494 42.7280728243978203, -82.3712199944157959 42.7280599954290707), (-82.3712237895553727 42.7280121021645982, -82.3712188768286779 42.7280085165726078), (-82.3712237895553727 42.7280121021645982, -82.3712204600770832 42.7280058855862706), (-82.3712238826876302 42.7280002045184446, -82.3712152446705517 42.7279928936360704), (-82.3712238826876302 42.7280002045184446, -82.3712204600770832 42.7280058855862706), (-82.3712263274094454 42.7279961066990239, -82.3712207627569342 42.7279863510948346), (-82.3712263274094454 42.7279961066990239, -82.3712238826876302 42.7280002045184446), (-82.3712263972586385 42.7279959902836950, -82.3712219734763096 42.7279849308278799), (-82.3712263972586385 42.7279959902836950, -82.3712263274094454 42.7279961066990239), (-82.3712264903908959 42.7280172011558079, -82.3712178290907531 42.7280102628024707), (-82.3712264903908959 42.7280172011558079, -82.3712237895553727 42.7280121021645982), (-82.3712266766554109 42.7279967120587116, -82.3712263274094454 42.7279961066990239), (-82.3712266766554109 42.7279967120587116, -82.3712263972586385 42.7279959902836950), (-82.3712270491844549 42.7280882377867783, -82.3711460008355800 42.7281314511551997), (-82.3712270491844549 42.7280882377867783, -82.3712232074787494 42.7280728243978203), (-82.3712302156812797 42.7280055829064338, -82.3712238826876302 42.7280002045184446), (-82.3712302156812797 42.7280055829064338, -82.3712266766554109 42.7279967120587116), (-82.3712321481756646 42.7281085639024170, -82.3711550579478171 42.7281322893455382), (-82.3712321481756646 42.7281085639024170, -82.3712270491844549 42.7280882377867783), (-82.3712331726305109 42.7280080741943706, -82.3712266766554109 42.7279967120587116), (-82.3712331726305109 42.7280080741943706, -82.3712302156812797 42.7280055829064338), (-82.3712365952410579 42.7280215085228150, -82.3712237895553727 42.7280121021645982), (-82.3712365952410579 42.7280215085228150, -82.3712302156812797 42.7280055829064338), (-82.3712383880370425 42.7279655360348301, -82.3711938475339167 42.7279384345472977), (-82.3712383880370425 42.7279655360348301, -82.3712219734763096 42.7279849308278799), (-82.3712388071322152 42.7280270498922548, -82.3712264903908959 42.7280172011558079), (-82.3712388071322152 42.7280270498922548, -82.3712365952410579 42.7280215085228150), (-82.3712406464943427 42.7280809734705329, -82.3712232074787494 42.7280728243978203), (-82.3712406464943427 42.7280809734705329, -82.3712270491844549 42.7280882377867783), (-82.3712429748008361 42.7279683532856751, -82.3712263972586385 42.7279959902836950), (-82.3712429748008361 42.7279683532856751, -82.3712383880370425 42.7279655360348301), (-82.3712433706129303 42.7280795299205067, -82.3712166649375064 42.7280466542328909), (-82.3712433706129303 42.7280795299205067, -82.3712406464943427 42.7280809734705329), (-82.3712439294064893 42.7280268636277327, -82.3712331726305109 42.7280080741943706), (-82.3712439294064893 42.7280268636277327, -82.3712365952410579 42.7280215085228150), (-82.3712469329218635 42.7280839071367069, -82.3712406464943427 42.7280809734705329), (-82.3712469329218635 42.7280839071367069, -82.3712433706129303 42.7280795299205067), (-82.3712479340936596 42.7279542437483570, -82.3712383880370425 42.7279655360348301), (-82.3712483997549469 42.7280347333036659, -82.3712388071322152 42.7280270498922548), (-82.3712483997549469 42.7280347333036659, -82.3712439294064893 42.7280268636277327), (-82.3712485627363975 42.7280585751621089, -82.3712112399833956 42.7280212524090999), (-82.3712485627363975 42.7280585751621089, -82.3712264903908959 42.7280172011558079), (-82.3712499131541733 42.7280760374607738, -82.3712108441712871 42.7280219276179807), (-82.3712499131541733 42.7280760374607738, -82.3712433706129303 42.7280795299205067), (-82.3712504020985250 42.7279559899782271, -82.3712429748008361 42.7279683532856751), (-82.3712504020985250 42.7279559899782271, -82.3712479340936596 42.7279542437483570), (-82.3712533357647061 42.7280633481904104, -82.3712388071322152 42.7280270498922548), (-82.3712533357647061 42.7280633481904104, -82.3712485627363975 42.7280585751621089), (-82.3712561297324868 42.7280727312655628, -82.3712485627363975 42.7280585751621089), (-82.3712561297324868 42.7280727312655628, -82.3712499131541733 42.7280760374607738), (-82.3712569213567036 42.7280723121703900, -82.3712533357647061 42.7280633481904104), (-82.3712569213567036 42.7280723121703900, -82.3712561297324868 42.7280727312655628), (-82.3712604138164295 42.7280704262421409, -82.3712533357647061 42.7280633481904104), (-82.3712604138164295 42.7280704262421409, -82.3712569213567036 42.7280723121703900), (-82.3712668399423364 42.7280670036316010, -82.3712483997549469 42.7280347333036659), (-82.3712668399423364 42.7280670036316010, -82.3712604138164295 42.7280704262421409))
./tests/ticket/bug599.xml: case1: test3: union(A, B): failed.
	Description: http://trac.osgeo.org/geos/ticket/599
	Geometry A: LINESTRING (0.9067521000000001 50.9278501000000006, 0.9065279000000001 50.9277141000000029, 0.9071019000000000 50.9273233000000047, 0.9079602000000001 50.9266741000000067, 0.9087112000000001 50.9260248000000004, 0.9090009000000001 50.9259166000000008, 0.9091082000000000 50.9258017000000009, 0.9091296000000001 50.9256394000000014, 0.9102562000000001 50.9248481000000055, 0.9109214000000001 50.9245032000000037, 0.9114792000000000 50.9241516000000018, 0.9124019000000001 50.9236646000000022, 0.9126809000000000 50.9234482000000028, 0.9134212000000000 50.9231845000000050, 0.9137216000000000 50.9230830000000054, 0.9137216000000000 50.9230221000000043, 0.9136572000000001 50.9229477000000017, 0.9131422000000000 50.9226366000000041, 0.9121552000000001 50.9223120000000051, 0.9118333000000001 50.9221835000000027, 0.9114685000000000 50.9219671000000034, 0.9112432000000000 50.9218521000000024, 0.9108784000000001 50.9213043000000027, 0.9108409000000001 50.9211609000000038, 0.9110179000000000 50.9208984999999998, 0.9112218000000001 50.9207294000000061, 0.9111292000000001 50.9206025000000011, 0.9110876000000001 50.9205454000000017, 0.9111292000000000 50.9206025000000011, 0.9111292000000001 50.9206025000000011, 0.9103903000000001 50.9202140000000014, 0.9095588000000001 50.9197014000000010)
	Geometry B: LINESTRING (0.9067521000000001 50.9278501000000006, 0.9065279000000001 50.9277141000000029, 0.9071019000000000 50.9273233000000047, 0.9079602000000001 50.9266741000000067, 0.9087112000000001 50.9260248000000004, 0.9090009000000001 50.9259166000000008, 0.9091082000000000 50.9258017000000009, 0.9091296000000001 50.9256394000000014, 0.9102562000000001 50.9248481000000055, 0.9109214000000001 50.9245032000000037, 0.9114792000000000 50.9241516000000018, 0.9124019000000001 50.9236646000000022, 0.9126809000000000 50.9234482000000028, 0.9134212000000000 50.9231845000000050, 0.9137216000000000 50.9230830000000054, 0.9137216000000000 50.9230221000000043, 0.9136572000000001 50.9229477000000017, 0.9131422000000000 50.9226366000000041, 0.9121552000000001 50.9223120000000051, 0.9118333000000001 50.9221835000000027, 0.9114685000000000 50.9219671000000034, 0.9112432000000000 50.9218521000000024, 0.9108784000000001 50.9213043000000027, 0.9108409000000001 50.9211609000000038, 0.9110179000000000 50.9208984999999998, 0.9112218000000001 50.9207294000000061, 0.9111292000000000 50.9206025000000011, 0.9103903000000001 50.9202140000000014, 0.9095588000000001 50.9197014000000010)
	Expected result: MULTILINESTRING ((0.9067520999999999 50.9278501000000006, 0.9065279000000001 50.9277141000000029), (0.9065279000000001 50.9277141000000029, 0.9071019000000000 50.9273233000000047), (0.9071019000000000 50.9273233000000047, 0.9079602000000002 50.9266741000000067), (0.9079602000000002 50.9266741000000067, 0.9087112000000001 50.9260248000000004), (0.9087112000000001 50.9260248000000004, 0.9090009000000002 50.9259166000000008), (0.9090009000000002 50.9259166000000008, 0.9091082000000000 50.9258017000000009), (0.9091082000000000 50.9258017000000009, 0.9091296000000000 50.9256394000000014), (0.9091296000000000 50.9256394000000014, 0.9102562000000000 50.9248481000000055), (0.9102562000000000 50.9248481000000055, 0.9109214000000002 50.9245032000000037), (0.9109214000000002 50.9245032000000037, 0.9114792000000000 50.9241516000000018), (0.9114792000000000 50.9241516000000018, 0.9124019000000000 50.9236646000000022), (0.9124019000000000 50.9236646000000022, 0.9126809000000000 50.9234482000000028), (0.9126809000000000 50.9234482000000028, 0.9134212000000000 50.9231845000000050), (0.9134212000000000 50.9231845000000050, 0.9137216000000000 50.9230830000000054), (0.9137216000000000 50.9230830000000054, 0.9137216000000000 50.9230221000000043), (0.9137216000000000 50.9230221000000043, 0.9136571999999999 50.9229477000000017), (0.9136571999999999 50.9229477000000017, 0.9131422000000000 50.9226366000000041), (0.9131422000000000 50.9226366000000041, 0.9121552000000001 50.9223120000000051), (0.9121552000000001 50.9223120000000051, 0.9118333000000000 50.9221835000000027), (0.9118333000000000 50.9221835000000027, 0.9114685000000000 50.9219671000000034), (0.9114685000000000 50.9219671000000034, 0.9112432000000000 50.9218521000000024), (0.9112432000000000 50.9218521000000024, 0.9108784000000000 50.9213043000000027), (0.9108784000000000 50.9213043000000027, 0.9108409000000000 50.9211609000000038), (0.9108409000000000 50.9211609000000038, 0.9110179000000000 50.9208984999999998), (0.9110179000000000 50.9208984999999998, 0.9112218000000000 50.9207294000000061), (0.9112218000000000 50.9207294000000061, 0.9111292000000000 50.9206025000000011), (0.9111292000000000 50.9206025000000011, 0.9110876000000002 50.9205454000000017), (0.9111292000000000 50.9206025000000011, 0.9103903000000000 50.9202140000000014), (0.9103903000000000 50.9202140000000014, 0.9095588000000002 50.9197014000000010))
	Obtained result: MULTILINESTRING ((0.9067520999598205 50.9278500999621713, 0.9065279001152441 50.9277141000907179), (0.9065279001152441 50.9277141000907179, 0.9071019000623147 50.9273232999088563), (0.9071019000623147 50.9273232999088563, 0.9079601999623609 50.9266741000876451), (0.9079601999623609 50.9266741000876451, 0.9087112000930848 50.9260247999164335), (0.9087112000930848 50.9260247999164335, 0.9090009000871798 50.9259166000238395), (0.9090009000871798 50.9259166000238395, 0.9091082000893327 50.9258016999638201), (0.9091082000893327 50.9258016999638201, 0.9091296000194572 50.9256394000085137), (0.9091296000194572 50.9256394000085137, 0.9102561999834740 50.9248480999201618), (0.9102561999834740 50.9248480999201618, 0.9109213999265157 50.9245031999713973), (0.9109213999265157 50.9245031999713973, 0.9114791999830583 50.9241516000880310), (0.9114791999830583 50.9241516000880310, 0.9124018999078315 50.9236646001049493), (0.9124018999078315 50.9236646001049493, 0.9126808999368644 50.9234482000869377), (0.9126808999368644 50.9234482000869377, 0.9134212001025260 50.9231845000579924), (0.9134212001025260 50.9231845000579924, 0.9137216000616833 50.9230830001000072), (0.9137216000616833 50.9230830001000072, 0.9137216000616833 50.9230220999855163), (0.9137216000616833 50.9230220999855163, 0.9136572000369563 50.9229476998846380), (0.9136572000369563 50.9229476998846380, 0.9131422000734932 50.9226365999604198), (0.9131422000734932 50.9226365999604198, 0.9121552000083391 50.9223120000498142), (0.9121552000083391 50.9223120000498142, 0.9118333000018805 50.9221834998862306), (0.9118333000018805 50.9221834998862306, 0.9114685000179961 50.9219671001010497), (0.9114685000179961 50.9219671001010497, 0.9112432000486280 50.9218520999238464), (0.9112432000486280 50.9218520999238464, 0.9108784000647436 50.9213042999434506), (0.9108784000647436 50.9213042999434506, 0.9108408998956068 50.9211609000156571), (0.9108408998956068 50.9211609000156571, 0.9110179000792601 50.9208985001130259), (0.9110179000792601 50.9208985001130259, 0.9112217998856730 50.9207294001059410), (0.9112217998856730 50.9207294001059410, 0.9111292001118718 50.9206024999545406), (0.9111292001118718 50.9206024999545406, 0.9110876000279299 50.9205454001018154), (0.9111292001118718 50.9206024999545406, 0.9103902999568708 50.9202139999066077), (0.9103902999568708 50.9202139999066077, 0.9095588000280687 50.9197013999614185))
Files: 77
Tests: 3174
Failed: 3
Succeeded: 3171
FAIL: testrunner
1 of 1 test failed
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130817/dd962618/attachment-0001.pgp>
