[geos-devel] 3.4.1, stray patch from pkgsrc
Greg Troxel gdt at ir.bbn.com
Sat Aug 17 18:09:31 PDT 2013
pkgsrc is carrying the following patch.  It strikes me that probably
there should be a configure-time feature test instead.
$NetBSD: patch-include-geos-platform.h.in,v 1.4 2012/03/12 09:46:06 fhajny Exp $
Fix isnan definition on NetBSD, DragonFly and SunOS platforms.
--- include/geos/platform.h.in.orig	2013-08-11 04:23:47.000000000 +0000
+++ include/geos/platform.h.in
@@ -91,11 +91,13 @@ extern "C"
 # elif defined(__MINGW32__) || defined(__CYGWIN__)
 // sandro furieri: sanitizing MinGW32
 #  define ISNAN(x) (std::isnan(x))
-# elif defined(__OSX__) || defined(__APPLE__)
+# elif defined(__OSX__) || defined(__APPLE__) || \
+       defined(__NetBSD__) || defined(__DragonFly__) ||	\
+       (defined(__sun) && defined(__GNUC__))
    // Hack for OS/X <cmath> incorrectly re-defining isnan() into oblivion.
    // It does leave a version in std.
-# elif defined(__sun) || defined(__sun__)
+# elif (defined(__sun) || defined(__sun__)) && defined(__SUNPRO_CC)
 #  include <math.h>
 #  define ISNAN(x) (::isnan(x))
 # endif
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130817/744f7061/attachment.pgp>
