[geos-devel] test failures
Greg Troxel
gdt at ir.bbn.com
Tue Aug 20 15:42:29 PDT 2013
Sandro Santilli <strk at keybit.net> writes:
> Theoretically -ffloat-store is already used when available,
> is that working for you guys ?
My build did use -ffloat-store. So apparently the issue is not about
excess precision. I have run paranoia on NetBSD/i386 - with
-ffloat-store it passes, and there are issues without it. On amd64
paranoia passes.
I updated the '32-bit regression errors' ticket, but regression tests
pass on NetBSD 5 amd64, and had 3 errors on NetbSD 6 i386.
I wonder if there is some type that is 32 on ILP32 and 64 on LP64, and
it's having overflow, and this isn't about i386 fp precision. I'll see
if I can manage to build on sparc (it may take all night), which is
ILP32 but does not have extended-precision double, just regular IEEE754.
> There's also a ticket to replace -ffloat-store with
> -fexcess-precision=standard
> http://trac.osgeo.org/geos/ticket/504
Hmm. I don't know how widespread that is.
If the extra precision causes real issues (vs slightly different but not
wrong answers) then there is perhaps something else going on.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130820/f181c55e/attachment.pgp>
