[geos-devel] [GEOS] #609: GEOSPointOnSurface returns EMPTY for single-point linestring
Martin Davis
mtnclimb at telus.net
Fri Jan 11 16:39:58 PST 2013
Fixes to JTS Centroid and InteriorPoint have been committed to SVN
(along with appropriate unit tests)
On 1/11/2013 9:45 AM, Martin Davis wrote:
> I just realized some corner cases, which require some clarification to
> deal with.
> One is geometries with multiple zero-length lines. In this case I
> think the geometries should be treated as points, and the centroid and
> interior point computed accordingly.
> A similar situation exists for polygons with no area (which are
> invalid, but it's still nice to return a sensible answer). A similar
> strategy should work - treat them as points. Polygons with extent but
> no area (eg POLYGON ((200 200, 200 300, 200 200, 200 200))) can be
> treated as if they are lines.
> In all cases, if geometry components of higher dimension are present,
> the lower-dimension geometries are ignored.
> This is going to require more significant change to handle - in
> particular, it points toward having single class for Centroid to
> handle all geometry types.
> On 1/11/2013 9:32 AM, Martin Davis wrote:
>> Just to clarify my original response, the primary constraint on
>> functions that return geometry values is that they return a valid
>> geometry that makes some sort of sense.
>> So in the case of centroid, regardless of what is "mathematically
>> correct" a valid sensible geometry should be returned (as opposed to
>> a meaningless geometry with NaN ordinates, as now happens).
>> In the case of interiorPoint the situation is even more clearcut -
>> obviously the interior point should be one of the points in the
>> geometry.
>>> Reporter: strk | Owner: geos-devel@…
>>> Type: defect | Status: new
>>> Priority: major | Milestone: 3.3.7
>>> Component: Default | Version: 3.3.6
>>> Severity: Unassigned | Keywords:
>>> Comment(by strk):
>>> So for GEOSCentroid the answer is correct, in that by definition the
>>> CentroidLine class computes the centroid of all segment's midpoint
>>> weighted by segment length, so a zero-length segment is not
>>> considered.
>>> Now, the algorithm of InteriorPointLine [1] is:
>>> - Find an interior vertex which is closest to the centroid of the
>>> linestring.
>>> - If there is no interior vertex, find the endpoint which is
>>> closest to
>>> the centroid.
>>> [1]
>>> http://www.vividsolutions.com/jts/javadoc/com/vividsolutions/jts/algorithm/InteriorPointLine.html
>>> But if there's no interior vertex both endpoints are equidistant
>>> to the
>>> centroid, aren't them ?
>>> Martin: am I missing anything ?
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
>> No virus found in this message.
>> Checked by AVG - www.avg.com
>> Version: 2013.0.2805 / Virus Database: 2637/6000 - Release Date:
>> 12/31/12
>> Internal Virus Database is out of date.
> Version: 2013.0.2805 / Virus Database: 2637/6000 - Release Date: 12/31/12
