[geos-devel] [GEOS] #609: GEOSPointOnSurface returns EMPTY for single-point linestring
Sandro Santilli
strk at keybit.net
Mon Jan 14 03:32:48 PST 2013
For the record, the SafeBisectorFinder was recently also improved with
changeset r717:
Date: Wed Dec 19 20:02:16 2012 +0000
Fixed Geometry.interiorPoint() to compute a true interior point in certain cases
But that changeset also came with no testcase
--strk;
On Mon, Jan 14, 2013 at 12:29:42PM +0100, Sandro Santilli wrote:
> Thank you Martin, I've started the port.
> One question: while porting InteriorPointArea I realized that GEOS
> and JTS are not in sync with reguard to the horizontalBisector method,
> but even if I copied the InteriorPointTest.xml test from JTS there are
> no failure in GEOS. Does it mean there are no test in JTS showing the
> need for using the private SafeBisectorFinder class (which is only
> in JTS) ? Can you think of any case that would fail with the old
> (as in GEOS) implementation of that ?
> --strk;
> On Fri, Jan 11, 2013 at 04:39:58PM -0800, Martin Davis wrote:
> > Fixes to JTS Centroid and InteriorPoint have been committed to SVN
> > (along with appropriate unit tests)
> > On 1/11/2013 9:45 AM, Martin Davis wrote:
> > >I just realized some corner cases, which require some
> > >clarification to deal with.
> > >One is geometries with multiple zero-length lines. In this case I
> > >think the geometries should be treated as points, and the centroid
> > >and interior point computed accordingly.
> > >A similar situation exists for polygons with no area (which are
> > >invalid, but it's still nice to return a sensible answer). A
> > >similar strategy should work - treat them as points. Polygons
> > >with extent but no area (eg POLYGON ((200 200, 200 300, 200 200,
> > >200 200))) can be treated as if they are lines.
> > >In all cases, if geometry components of higher dimension are
> > >present, the lower-dimension geometries are ignored.
> > >This is going to require more significant change to handle - in
> > >particular, it points toward having single class for Centroid to
> > >handle all geometry types.
> > >On 1/11/2013 9:32 AM, Martin Davis wrote:
> > >>Just to clarify my original response, the primary constraint on
> > >>functions that return geometry values is that they return a
> > >>valid geometry that makes some sort of sense.
> > >>So in the case of centroid, regardless of what is
> > >>"mathematically correct" a valid sensible geometry should be
> > >>returned (as opposed to a meaningless geometry with NaN
> > >>ordinates, as now happens).
> > >>In the case of interiorPoint the situation is even more clearcut
> > >>- obviously the interior point should be one of the points in
> > >>the geometry.
> > >>> Reporter: strk | Owner: geos-devel@…
> > >>> Type: defect | Status: new
> > >>> Priority: major | Milestone: 3.3.7
> > >>>Component: Default | Version: 3.3.6
> > >>> Severity: Unassigned | Keywords:
> > >>>Comment(by strk):
> > >>> So for GEOSCentroid the answer is correct, in that by definition the
> > >>> CentroidLine class computes the centroid of all segment's midpoint
> > >>> weighted by segment length, so a zero-length segment is not
> > >>>considered.
> > >>> Now, the algorithm of InteriorPointLine [1] is:
> > >>> - Find an interior vertex which is closest to the centroid of the
> > >>> linestring.
> > >>> - If there is no interior vertex, find the endpoint which
> > >>>is closest to
> > >>> the centroid.
> > >>> [1]
> > >>>http://www.vividsolutions.com/jts/javadoc/com/vividsolutions/jts/algorithm/InteriorPointLine.html
> > >>> But if there's no interior vertex both endpoints are
> > >>>equidistant to the
> > >>> centroid, aren't them ?
> > >>> Martin: am I missing anything ?
