[geos-devel] vector::_M_range_insert error
Sandro Santilli
strk at keybit.net
Wed Jul 17 05:57:18 PDT 2013
On Wed, Jul 17, 2013 at 06:24:44PM +0530, vishal tiwari wrote:
> Hi Peter,
> It was giving me the error that i specified before, because the object was
> been deleted when it was returned to the different function (i think this
> was the reason). So i made a copy of it using clone(), and returned its
> pointer, and it worked. :)
Yep, those kind of errors are common when you hand around pointers to
memory that's released before use. Valgrind is an excellent tool to
find these cases (hint: use it against your testcases, those memory
errors do not _always_ get to the surface).
--strk;
> Thanks,
> Vishal
> On 17 July 2013 15:15, Peter Körner <osm-lists at mazdermind.de> wrote:
> > Hi vishal tiwari,
> > Am 17.07.2013 09:58, schrieb vishal tiwari:
> > > sorry to bother you, i just fixed it. :)
> > would you mind telling us what your issue was, so we (partly also not
> > that familar witc C++) can take part of your solution?
> > Peter
