[geos-devel] [GEOS] #522: Exception on overlay between valid linestrings [JTS fails too]
geos-trac at osgeo.org
Wed Jul 17 13:20:00 PDT 2013
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: GEOS Future
Component: Default | Version: 3.3.2
Severity: Unassigned | Keywords: jtsfail
Comment(by strk):
Running this test after snapping improvements:
Trying with original input.
Original exception: TopologyException: found non-noded intersection
between LINESTRING (-1.1205e+06 851294, -1.1205e+06 851343) and LINESTRING
(-1.1205e+06 851343, -1.1205e+06 851342) at -1120500.0000001257
851343.3885007716
Trying with Common Bits Remover (CBR)
CBR: result (after common-bits addition) is INVALID: Self-intersection at
or near point -1120500.0000001257 851294.29919294897
(-1120500.0000001257285 851294.29919294896536)
CBR: result (after common-bits addition) fix_self_intersection
(UnaryUnion)
CBR: result (after common-bits addition and fix_self_intersections) is
INVALID: Self-intersection at or near point -1120500.0000001257
851294.29919294897 (-1120500.0000001257285 851294.29919294896536)
CBR: TopologyException: Result of overlay became invalid after re-addin
common bits of operand coordinates: Self-intersection at or near point
-1120500.0000001257 851294.29919294897 at -1120500.0000001257
851294.29919294897
Trying with snapping
Computed snap tolerance: 7.8501591251697397784e-09
Computed common bits: -1120512 849920
SNAP: snapped geom 0 fix_self_intersection (UnaryUnion)
SNAP: snapped geom 1 fix_self_intersection (UnaryUnion)
SNAP: TopologyException: found non-noded intersection between LINESTRING
(12 1379.82, 12 1423.39) and LINESTRING (12 1423.39, 12 1422.24) at
11.999999874271452 1423.3885007716017
EXCEPTION on case 1 test 1: TopologyException: found non-noded
intersection between LINESTRING (-1.1205e+06 851294, -1.1205e+06 851343)
and LINESTRING (-1.1205e+06 851343, -1.1205e+06 851342) at
-1120500.0000001257 851343.3885007716
Basically this time snapping does NOT introduce any invalidity, still the
exception is thrown :(
Ticket URL: <http://trac.osgeo.org/geos/ticket/522#comment:5>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
