[geos-devel] [GEOS] #637: PrepairedPoint.h intersects is missing a const
GEOS geos-trac at osgeo.org
Thu Jul 18 12:21:44 PDT 2013
 Reporter:  goatbar     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  3.3.8
 Severity:  Unassigned  |    Keywords:
 I believe this change is correct.  It helps a llvm compiler warning on my
 machine.
 In include/geos/geom/prep/PerparedPoint.h:
         bool intersects(const geom::Geometry* g);
 Should change to:
         virtual bool intersects(const geom::Geometry* g) const;
 and src/geom/prep/PreparedPoint.cpp
 PreparedPoint::intersects(const geom::Geometry* g)
 to
 PreparedPoint::intersects(const geom::Geometry* g) const
Ticket URL: <http://trac.osgeo.org/geos/ticket/637>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
