[geos-devel] [GEOS] #459: Union fails to fully node input linework
GEOS geos-trac at osgeo.org
Mon Jul 29 06:39:10 PDT 2013
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.0
Component:  Default     |     Version:  3.3.0
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Offending inputs (to recap):
 A:
 0102000000080000003C0AD7E32D4E3A4152B81E250A4452412085EB91284A3A417A14AE2719445241285C8F42354A3A41A4703D6A1E445241CCCCCC0C474A3A415C8FC2851E445241C4F5289C4B4A3A415C8FC2C52B445241BE08DEAE534E3A41B1B518AB1F44524100000000604E3A419A9999C9064452413C0AD7E32D4E3A4152B81E250A445241
 B:
 010200000009000000B89C2EFE364A3A41DFC087291F445241545C8F42354A3A41A4703D6A1E4452418CEC6D6F354A3A41FE7E44D31D44524136C80FA4394A3A412D7F89121D445241409B06043D4A3A415860C1CC1C445241360D6849404A3A4136B46EC91C445241FC25CB4B474A3A41B72FD41F1D445241CDCCCC0C474A3A415C8FC2851E445241181E3474434A3A4116CE6F471F445241
 They are 2 linestrings. The first one is closed and makes a valid polygon.
 The second one is simple and crosses the first one exactly in two points.
 Theoretically their union would polygonize into 2 rings, but the union
 operation instead fails to produce a correctly noded result.
Ticket URL: <http://trac.osgeo.org/geos/ticket/459#comment:5>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
