[geos-devel] [GEOS] #630: CMake with mingw fail
geos-trac at osgeo.org
Tue Jun 4 21:47:26 PDT 2013
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
Comment(by robe):
I made progress on this by looking at notes from http://osgeo-
org.1560.x6.nabble.com/Compiling-geos-with-mingw64-td5034567.html
I was able to compile with the below and some modifications to files which
I'll clean up and provide a patch for once I'm done
cmake -G"MSYS Makefiles"
-DCMAKE_INSTALL_PREFIX:PATH=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}
-DHAVE_STD_ISNAN=1 -DHAVE_LONG_LONG_INT_64=1 -DGEOS_ENABLE_INLINE=ON
-DGEOS_ENABLE_TESTS=ON
make
make install
make test
make check
However I don't think -DGEOS_ENABLE_INLINE=ON is working. It says it is
in the output, but I get linker failures unless I explicitly change
geos/inline.h
# define INLINE inline
as David did.
I also think you might be missing an important include. I had to change
some conditions in profiler.h to
#if defined(__MINGW32__) && !defined( __MINGW64__)
when I really want to do:
#if defined(__MINGW32__) && !defined(__MINGW64_VERSION_MAJOR)
to properly handle building both win32 and win64 binaries with mingw64
chain
as detailed here:
http://sourceforge.net/mailarchive/message.php?msg_id=28305973
So after that long exercise I am here:
Running tests...
Test project C:/ming64/projects/geos/branches/geos-3.4/build/mingw
Start 1: geos_unit
1/4 Test #1: geos_unit ........................ Passed 0.24 sec
Start 2: xmltester
2/4 Test #2: xmltester ........................ Passed 6.53 sec
Start 3: bug234
3/4 Test #3: bug234 ........................... Passed 0.01 sec
Start 4: TestSweepLineSpeed
4/4 Test #4: TestSweepLineSpeed ............... Passed 1.70 sec
100% tests passed, 0 tests failed out of 4
Total Test time (real) = 8.51 sec
Scanning dependencies of target check
make[3]: ctest: Command not found
make[3]: *** [CMakeFiles/check] Error 127
make[2]: *** [CMakeFiles/check.dir/all] Error 2
make[1]: *** [CMakeFiles/check.dir/rule] Error 2
make: *** [check] Error 2
which is good progress I guess
Ticket URL: <http://trac.osgeo.org/geos/ticket/630#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
