[geos-devel] [GEOS] #630: CMake with mingw fail
geos-trac at osgeo.org
Tue Jun 4 22:27:52 PDT 2013
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
Comment(by robe):
The ctest issue was because I didn't have cmake bin folder in my search
path. I was using an alias for cmake to run. After adding to my path --
yeh complete success.
Linking CXX executable ../../bin/TestSweepLineSpeed.exe
[100%] Built target TestSweepLineSpeed
Scanning dependencies of target bug234
[100%] Building CXX object
tests/bigtest/CMakeFiles/bug234.dir/bug234.cpp.obj
c:/ming64/projects/geos/branches/geos-3.4/tests/bigtest/bug234.cpp:1:0:
warning:
-fPIC ignored for target (all code is position independent) [enabled by
default
#include <vector>
Linking CXX executable ../../bin/bug234.exe
[100%] Built target bug234
Running tests...
Test project C:/ming64/projects/geos/branches/geos-3.4/build/mingw
Start 1: geos_unit
1/4 Test #1: geos_unit ........................ Passed 0.13 sec
Start 2: xmltester
2/4 Test #2: xmltester ........................ Passed 6.44 sec
Start 3: bug234
3/4 Test #3: bug234 ........................... Passed 0.01 sec
Start 4: TestSweepLineSpeed
4/4 Test #4: TestSweepLineSpeed ............... Passed 1.72 sec
100% tests passed, 0 tests failed out of 4
Total Test time (real) = 8.32 sec
Scanning dependencies of target check
Start 1: geos_unit
1/4 Test #1: geos_unit ........................ Passed 0.11 sec
Start 2: xmltester
2/4 Test #2: xmltester ........................ Passed 6.43 sec
Start 3: bug234
4/4 Test #4: TestSweepLineSpeed ............... Passed 1.71 sec
Total Test time (real) = 8.29 sec
Built target check
I'll attach a patch once I've cleaned up the junk I shouldn't have put
in. n test wt my curent mingw64. This is using mingw64 gcc 4.8
x86_64-w64-mingw32-gcc-4.8.0-win64_rubenvb.7z from
http://sourceforge.net/projects/mingw-w64/files/Toolchains%20targetting%20Win64/Personal%20Builds/rubenvb/gcc-4.8-release/
I still need to test with win32 also.
Ticket URL: <http://trac.osgeo.org/geos/ticket/630#comment:3>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
