[geos-devel] Call for JTS users to test right-sided offset curve	problem
    Mateusz Loskot
    mateusz at loskot.net
    Tue Jun 11 08:50:12 PDT 2013
Are there any JTS users around who could test the case
reported here:
http://trac.osgeo.org/geos/ticket/633
There is BufferBuilderTest.cpp attached with two trivial test cases,
one for left- and the other for right-side offset curve.
Line with test failure marked with // XXX
The problem is in test case #2, the right-side offset curve is
expected to have 5 vertices, but it is produced with Zero vertices
Does JTS produce the same result?
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
