[geos-devel] Doubts
vishal tiwari
hi.vishal123 at gmail.com
Fri Jun 21 04:20:35 PDT 2013
Hey,
I am facing some very silly problems when i try to compile
QuadEdgeSubdivision.cpp.
I have declared my getVoronoiCellPolygons as :
void
QuadEdgeSubdivision::getVoronoiCellPolygons(std::vector<geom::Geometry *>
&cells ,const geom::GeometryFactory& geomFact)
And I have definition it in QuadEdgeSubdiviion.h as:
void getVoronoiCellPolygons( std::vector<geom::Geometry *> &cells , const
geom::GeomtryFactory &geomFact);
And i am getting the following compilation error:
In file included from QuadEdgeSubdivision.cpp:18:
../../../include/geos/triangulate/quadedge/QuadEdgeSubdivision.h:425:
error: expected unqualified-id before ‘&’ token
error: expected ‘)’ before ‘&’ token
error: expected ‘;’ before ‘&’ token
Similar error is shown getVoronoiCellPolygon method:
getVoronoiCellPolygon.cpp:
geos::geom::Polygon*
QuadEdgeSubdivision::getVoronoiCellPolygon(QuadEdge* qe ,const
geom::GeomtryFactory& geomFact)
getVoronoiCellPolygon.h
geos::geom::Polygon* getVoronoiCellPolygon(QuadEdge* qe ,const
geom::GeomtryFactory& geomFact);
../../../include/geos/triangulate/quadedge/QuadEdgeSubdivision.h:442:
I have quantified it using the "::" operator and specified to which class
the methods belong to. Please help me out with this.
--Vishal
On 19 June 2013 18:36, Sandro Santilli <strk at keybit.net> wrote:
> On Wed, Jun 19, 2013 at 06:09:31PM +0530, vishal tiwari wrote:
> > Hey strk,
> > I was porting some methods in QuadEdgeSubdivision class, and saw some
> > methods like, geom::Triangle::circumcentre()
> > ,geom::CoordinateList::closeRing(), not there, which are required, so
> > should i port them, or expand the functions in QuadEdgeSubdivision class
> > itself?
> You should port them to the respective classes (Triangle, CoordinateList).
> > I see one unit test case for VoronoiDiagram in JTS, so i will be building
> > some of my own. :)
> Thanks! Consider also adding testcases for the new methods in Triangle
> and CoordinateList. The more tests we have, the better :)
> --strk;
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Vishal Tiwari
Undergraduate
Computer Science and Engineering
Lab for Spatial Informatics
IIIT-Hyderabad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130621/d000f278/attachment.html>
