[geos-devel] GSoC Weekly Report
    vishal tiwari
    hi.vishal123 at gmail.com
    Fri Jun 21 11:47:52 PDT 2013
*Week 1*
*1. Work Done :*
   - Have ported the methods that are in
   geos/triangualte/quadedge/QuadEdgeSubdivion.cpp. The methods are as such:
      - getVoronoiDiagram : Gets the cells in the Voronoi diagram for a
      triangulation.
      - getVoronoiCellPolygons : Gets the polygons for the Voronoi Cells
      for a triangulation.
      - getVoronoiCellPolygon : Gets the Voronoi cell around a site
      specified by the origin of a
QuadEdge?<http://trac.osgeo.org/geos/wiki/QuadEdge>
      - getVertexUniqueEdges : Gets a collection of
QuadEdges?<http://trac.osgeo.org/geos/wiki/QuadEdges> whose
      origin vertices are a unique set which includes all vertices in the
      subdivision. The frame vertices can be included if required.
   - Class TriangleCircumcentreVisitor?<http://trac.osgeo.org/geos/wiki/TriangleCircumcentreVisitor>
was
   also ported.
   - More methods like geos::geom::Triangle::circumcentre, and
   geos::geom::closeRing that were required in the above functions were also
   ported.
*2. Problem Faced :*
   - I am having some silly problems during compilation which i am working
   out with strk, it will be solved soon.
*3. Work to be done in the next week :*
   - Solve the errors that are coming as of now.
   - Port the classes left, and see the working of the methods ported.
   - Start with the port of class
VoronoiDiagramBuilder?<http://trac.osgeo.org/geos/wiki/VoronoiDiagramBuilder>
Regards,
Vishal Tiwari
Undergraduate
Computer Science and Engineering
Lab for Spatial Informatics
IIIT-Hyderabad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130622/157b7108/attachment.html>
