[geos-devel] GSoC Weekly Report
Sandro Santilli strk at keybit.net
Wed Jun 26 09:40:32 PDT 2013
Thanks for the report Vishal.
One thing: before porting more classes I suggest you port or write
the unit tests associated with each class you ported already.
Same thing for new methods (possibly easier as a unit test for the
class may already be available).
Every portion of code + docs (doxygen) + test is a good candidate for
merging into the official repository.
I'm a fan of incremental work :)
--strk;
On Sat, Jun 22, 2013 at 12:17:52AM +0530, vishal tiwari wrote:
> *Week 1*
> *1. Work Done :*
>    - Have ported the methods that are in
>    geos/triangualte/quadedge/QuadEdgeSubdivion.cpp. The methods are as such:
>       - getVoronoiDiagram : Gets the cells in the Voronoi diagram for a
>       triangulation.
>       - getVoronoiCellPolygons : Gets the polygons for the Voronoi Cells
>       for a triangulation.
>       - getVoronoiCellPolygon : Gets the Voronoi cell around a site
>       specified by the origin of a
> QuadEdge?<http://trac.osgeo.org/geos/wiki/QuadEdge>
>       - getVertexUniqueEdges : Gets a collection of
> QuadEdges?<http://trac.osgeo.org/geos/wiki/QuadEdges> whose
>       origin vertices are a unique set which includes all vertices in the
>       subdivision. The frame vertices can be included if required.
>    - Class TriangleCircumcentreVisitor?<http://trac.osgeo.org/geos/wiki/TriangleCircumcentreVisitor>
> was
>    also ported.
>    - More methods like geos::geom::Triangle::circumcentre, and
>    geos::geom::closeRing that were required in the above functions were also
>    ported.
> *2. Problem Faced :*
>    - I am having some silly problems during compilation which i am working
>    out with strk, it will be solved soon.
> *3. Work to be done in the next week :*
>    - Solve the errors that are coming as of now.
>    - Port the classes left, and see the working of the methods ported.
>    - Start with the port of class
> VoronoiDiagramBuilder?<http://trac.osgeo.org/geos/wiki/VoronoiDiagramBuilder>
> Regards,
