[geos-devel] GSoC Weekly Report
vishal tiwari
hi.vishal123 at gmail.com
Fri Jun 28 02:01:08 PDT 2013
Hey,
I have ported a part of VoronoiDiagramBuilder class. It will be over soon.
So, I will start writing the test cases for the methods and classes that i
have ported so far, in the next week.
Thanks,
On 26 June 2013 22:10, Sandro Santilli <strk at keybit.net> wrote:
> Thanks for the report Vishal.
> One thing: before porting more classes I suggest you port or write
> the unit tests associated with each class you ported already.
> Same thing for new methods (possibly easier as a unit test for the
> class may already be available).
> Every portion of code + docs (doxygen) + test is a good candidate for
> merging into the official repository.
> I'm a fan of incremental work :)
> --strk;
> On Sat, Jun 22, 2013 at 12:17:52AM +0530, vishal tiwari wrote:
> > *Week 1*
> > *1. Work Done :*
> > - Have ported the methods that are in
> > geos/triangualte/quadedge/QuadEdgeSubdivion.cpp. The methods are as
> such:
> > - getVoronoiDiagram : Gets the cells in the Voronoi diagram for a
> > triangulation.
> > - getVoronoiCellPolygons : Gets the polygons for the Voronoi Cells
> > for a triangulation.
> > - getVoronoiCellPolygon : Gets the Voronoi cell around a site
> > specified by the origin of a
> > QuadEdge?<http://trac.osgeo.org/geos/wiki/QuadEdge>
> > - getVertexUniqueEdges : Gets a collection of
> > QuadEdges?<http://trac.osgeo.org/geos/wiki/QuadEdges> whose
> > origin vertices are a unique set which includes all vertices in the
> > subdivision. The frame vertices can be included if required.
> > - Class TriangleCircumcentreVisitor?<
> http://trac.osgeo.org/geos/wiki/TriangleCircumcentreVisitor>
> > was
> > also ported.
> > - More methods like geos::geom::Triangle::circumcentre, and
> > geos::geom::closeRing that were required in the above functions were
> also
> > ported.
> > *2. Problem Faced :*
> > - I am having some silly problems during compilation which i am
> working
> > out with strk, it will be solved soon.
> > *3. Work to be done in the next week :*
> > - Solve the errors that are coming as of now.
> > - Port the classes left, and see the working of the methods ported.
> > - Start with the port of class
> > VoronoiDiagramBuilder?<
> http://trac.osgeo.org/geos/wiki/VoronoiDiagramBuilder>
> > Regards,
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Vishal Tiwari
Undergraduate
Computer Science and Engineering
Lab for Spatial Informatics
IIIT-Hyderabad
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20130628/c8715a21/attachment.html>
