[geos-devel] python bindings
Paolo Corti
pcorti at gmail.com
Fri Mar 1 10:17:17 PST 2013
Hi
are still supported Python swig bindings?
I would like to give a try to MakeValid on some shapefiles, but I
cannot figure out why Python bindings are not available on my box:
$ ./configure --enable-python
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... yes
checking whether a statically linked program can dlopen itself... no
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether we are using the GNU C++ compiler... (cached) yes
checking whether g++ accepts -g... (cached) yes
checking dependency style of g++... (cached) gcc3
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking for library containing strerror... none required
checking whether make sets $(MAKE)... (cached) yes
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking whether closedir returns void... no
checking for working memcmp... yes
checking for strftime... yes
checking for vprintf... yes
checking for _doprnt... no
checking for working alloca.h... yes
checking for alloca... yes
checking for dirent.h that defines DIR... (cached) yes
checking for library containing opendir... (cached) none required
checking for ANSI C header files... (cached) yes
checking for memory.h... (cached) yes
checking for unistd.h... (cached) yes
checking ieeefp.h usability... no
checking ieeefp.h presence... no
checking for ieeefp.h... no
checking sys/file.h usability... yes
checking sys/file.h presence... yes
checking for sys/file.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for strchr... yes
checking for memcpy... yes
checking for gettimeofday... yes
checking whether stat file-mode macros are broken... no
checking whether struct tm is in sys/time.h or time.h... time.h
checking for size_t... yes
checking for an ANSI C-conforming const... yes
checking if requested to force inline functions... yes
checking if requested to enable assert macros... yes
checking if requested libstdc++ debug mode... no
checking if g++ supports -pedantic... yes
checking if g++ supports -Wall... yes
checking if g++ supports -ansi... yes
checking if g++ supports -Wno-long-long... yes
checking if g++ supports -ffloat-store... yes
checking for finite... yes
checking for isfinite... yes
checking for isnan... yes
checking whether int64_t is 64 bits... no
checking whether long int is 64 bits... no
checking whether long long int is 64 bits... yes
checking for swig... /usr/bin/swig
checking for SWIG version... 2.0.4
configure: SWIG executable is '/usr/bin/swig'
configure: SWIG library directory is '/usr/share/swig2.0'
checking for python... /usr/bin/python
checking for python version... 2.7
checking for python platform... linux2
checking for python script directory... ${prefix}/lib/python2.7/site-packages
checking for python extension module directory...
${exec_prefix}/lib/python2.7/site-packages
checking for Python include path... /usr/include/python2.7
checking for Python library path... /usr/lib/python2.7/config
checking python extra libraries...
checking OS-specific settings... configure: creating ./config.status
config.status: creating Makefile
config.status: creating capi/Makefile
config.status: creating capi/geos_c.h
config.status: creating doc/Doxyfile
config.status: creating doc/Makefile
config.status: creating macros/Makefile
config.status: creating src/Makefile
config.status: creating src/algorithm/Makefile
config.status: creating src/algorithm/locate/Makefile
config.status: creating src/algorithm/distance/Makefile
config.status: creating src/geom/Makefile
config.status: creating src/geom/prep/Makefile
config.status: creating src/geom/util/Makefile
config.status: creating src/geomgraph/Makefile
config.status: creating src/geomgraph/index/Makefile
config.status: creating include/Makefile
config.status: creating include/geos/Makefile
config.status: creating include/geos/algorithm/Makefile
config.status: creating include/geos/algorithm/locate/Makefile
config.status: creating include/geos/algorithm/distance/Makefile
config.status: creating include/geos/geom/Makefile
config.status: creating include/geos/geom/prep/Makefile
config.status: creating include/geos/geom/util/Makefile
config.status: creating include/geos/geomgraph/Makefile
config.status: creating include/geos/geomgraph/index/Makefile
config.status: creating include/geos/index/Makefile
config.status: creating include/geos/index/bintree/Makefile
config.status: creating include/geos/index/chain/Makefile
config.status: creating include/geos/index/intervalrtree/Makefile
config.status: creating include/geos/index/quadtree/Makefile
config.status: creating include/geos/index/strtree/Makefile
config.status: creating include/geos/index/sweepline/Makefile
config.status: creating include/geos/io/Makefile
config.status: creating include/geos/linearref/Makefile
config.status: creating include/geos/noding/Makefile
config.status: creating include/geos/noding/snapround/Makefile
config.status: creating include/geos/operation/Makefile
config.status: creating include/geos/operation/buffer/Makefile
config.status: creating include/geos/operation/distance/Makefile
config.status: creating include/geos/operation/linemerge/Makefile
config.status: creating include/geos/operation/overlay/Makefile
config.status: creating include/geos/operation/overlay/snap/Makefile
config.status: creating include/geos/operation/polygonize/Makefile
config.status: creating include/geos/operation/predicate/Makefile
config.status: creating include/geos/operation/relate/Makefile
config.status: creating include/geos/operation/sharedpaths/Makefile
config.status: creating include/geos/operation/union/Makefile
config.status: creating include/geos/operation/valid/Makefile
config.status: creating include/geos/planargraph/Makefile
config.status: creating include/geos/planargraph/algorithm/Makefile
config.status: creating include/geos/precision/Makefile
config.status: creating include/geos/simplify/Makefile
config.status: creating include/geos/util/Makefile
config.status: creating include/geos/version.h
config.status: creating src/index/Makefile
config.status: creating src/index/bintree/Makefile
config.status: creating src/index/chain/Makefile
config.status: creating src/index/intervalrtree/Makefile
config.status: creating src/index/quadtree/Makefile
config.status: creating src/index/strtree/Makefile
config.status: creating src/index/sweepline/Makefile
config.status: creating src/io/Makefile
config.status: creating src/linearref/Makefile
config.status: creating src/noding/Makefile
config.status: creating src/noding/snapround/Makefile
config.status: creating src/operation/Makefile
config.status: creating src/operation/buffer/Makefile
config.status: creating src/operation/distance/Makefile
config.status: creating src/operation/linemerge/Makefile
config.status: creating src/operation/overlay/Makefile
config.status: creating src/operation/polygonize/Makefile
config.status: creating src/operation/predicate/Makefile
config.status: creating src/operation/relate/Makefile
config.status: creating src/operation/sharedpaths/Makefile
config.status: creating src/operation/union/Makefile
config.status: creating src/operation/valid/Makefile
config.status: creating src/planargraph/Makefile
config.status: creating src/precision/Makefile
config.status: creating src/simplify/Makefile
config.status: creating src/util/Makefile
config.status: creating swig/geos.i
config.status: creating swig/Makefile
config.status: creating swig/python/Makefile
config.status: creating swig/python/tests/Makefile
config.status: creating swig/ruby/Makefile
config.status: creating swig/ruby/test/Makefile
config.status: creating php/Makefile
config.status: creating php/test/Makefile
config.status: creating tests/Makefile
config.status: creating tests/bigtest/Makefile
config.status: creating tests/unit/Makefile
config.status: creating tests/perf/Makefile
config.status: creating tests/perf/operation/Makefile
config.status: creating tests/perf/operation/buffer/Makefile
config.status: creating tests/perf/operation/predicate/Makefile
config.status: creating tests/perf/capi/Makefile
config.status: creating tests/xmltester/Makefile
config.status: creating tests/geostest/Makefile
config.status: creating tests/thread/Makefile
config.status: creating tools/Makefile
config.status: creating tools/geos-config
config.status: creating include/config.h
config.status: include/config.h is unchanged
config.status: creating include/geos/platform.h
config.status: include/geos/platform.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
Swig: true
Python bindings: true
Ruby bindings: false
PHP bindings: false
after make and installing no bindings...
ideas?
thanks in advance
p
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
