[geos-devel] python bindings
Paolo Corti
pcorti at gmail.com
Fri Mar 1 10:27:03 PST 2013
Uh, I have just learnt that ST_MakeValid is in the LibWGeom PostGIS
library, so not a GEOS thing at all.
In any case I would still be interested in understanding why I cannot
have Python bindings in my box
cheers
p
On Fri, Mar 1, 2013 at 7:17 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Hi
> are still supported Python swig bindings?
> I would like to give a try to MakeValid on some shapefiles, but I
> cannot figure out why Python bindings are not available on my box:
> $ ./configure --enable-python
> checking build system type... i686-pc-linux-gnu
> checking host system type... i686-pc-linux-gnu
> checking target system type... i686-pc-linux-gnu
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for a thread-safe mkdir -p... /bin/mkdir -p
> checking for gawk... no
> checking for mawk... mawk
> checking whether make sets $(MAKE)... yes
> checking whether to enable maintainer-specific portions of Makefiles... no
> checking for gcc... gcc
> checking whether the C compiler works... yes
> checking for C compiler default output file name... a.out
> checking for suffix of executables...
> checking whether we are cross compiling... no
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ISO C89... none needed
> checking for style of include used by make... GNU
> checking dependency style of gcc... gcc3
> checking for a sed that does not truncate output... /bin/sed
> checking for grep that handles long lines and -e... /bin/grep
> checking for egrep... /bin/grep -E
> checking for fgrep... /bin/grep -F
> checking for ld used by gcc... /usr/bin/ld
> checking if the linker (/usr/bin/ld) is GNU ld... yes
> checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
> checking the name lister (/usr/bin/nm -B) interface... BSD nm
> checking whether ln -s works... yes
> checking the maximum length of command line arguments... 1572864
> checking whether the shell understands some XSI constructs... yes
> checking whether the shell understands "+="... yes
> checking for /usr/bin/ld option to reload object files... -r
> checking for objdump... objdump
> checking how to recognize dependent libraries... pass_all
> checking for ar... ar
> checking for strip... strip
> checking for ranlib... ranlib
> checking command to parse /usr/bin/nm -B output from gcc object... ok
> checking how to run the C preprocessor... gcc -E
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking for dlfcn.h... yes
> checking for objdir... .libs
> checking if gcc supports -fno-rtti -fno-exceptions... no
> checking for gcc option to produce PIC... -fPIC -DPIC
> checking if gcc PIC flag -fPIC -DPIC works... yes
> checking if gcc static flag -static works... yes
> checking if gcc supports -c -o file.o... yes
> checking if gcc supports -c -o file.o... (cached) yes
> checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
> checking whether -lc should be explicitly linked in... no
> checking dynamic linker characteristics... GNU/Linux ld.so
> checking how to hardcode library paths into programs... immediate
> checking for shl_load... no
> checking for shl_load in -ldld... no
> checking for dlopen... no
> checking for dlopen in -ldl... yes
> checking whether a program can dlopen itself... yes
> checking whether a statically linked program can dlopen itself... no
> checking whether stripping libraries is possible... yes
> checking if libtool supports shared libraries... yes
> checking whether to build shared libraries... yes
> checking whether to build static libraries... yes
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking dependency style of g++... gcc3
> checking whether we are using the GNU C++ compiler... (cached) yes
> checking whether g++ accepts -g... (cached) yes
> checking dependency style of g++... (cached) gcc3
> checking how to run the C++ preprocessor... g++ -E
> checking for ld used by g++... /usr/bin/ld
> checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
> checking for g++ option to produce PIC... -fPIC -DPIC
> checking if g++ PIC flag -fPIC -DPIC works... yes
> checking if g++ static flag -static works... yes
> checking if g++ supports -c -o file.o... yes
> checking if g++ supports -c -o file.o... (cached) yes
> checking for library containing strerror... none required
> checking whether make sets $(MAKE)... (cached) yes
> checking for dirent.h that defines DIR... yes
> checking for library containing opendir... none required
> checking whether closedir returns void... no
> checking for working memcmp... yes
> checking for strftime... yes
> checking for vprintf... yes
> checking for _doprnt... no
> checking for working alloca.h... yes
> checking for alloca... yes
> checking for dirent.h that defines DIR... (cached) yes
> checking for library containing opendir... (cached) none required
> checking for ANSI C header files... (cached) yes
> checking for memory.h... (cached) yes
> checking for unistd.h... (cached) yes
> checking ieeefp.h usability... no
> checking ieeefp.h presence... no
> checking for ieeefp.h... no
> checking sys/file.h usability... yes
> checking sys/file.h presence... yes
> checking for sys/file.h... yes
> checking sys/time.h usability... yes
> checking sys/time.h presence... yes
> checking for sys/time.h... yes
> checking for strchr... yes
> checking for memcpy... yes
> checking for gettimeofday... yes
> checking whether stat file-mode macros are broken... no
> checking whether struct tm is in sys/time.h or time.h... time.h
> checking for size_t... yes
> checking for an ANSI C-conforming const... yes
> checking if requested to force inline functions... yes
> checking if requested to enable assert macros... yes
> checking if requested libstdc++ debug mode... no
> checking if g++ supports -pedantic... yes
> checking if g++ supports -Wall... yes
> checking if g++ supports -ansi... yes
> checking if g++ supports -Wno-long-long... yes
> checking if g++ supports -ffloat-store... yes
> checking for finite... yes
> checking for isfinite... yes
> checking for isnan... yes
> checking whether int64_t is 64 bits... no
> checking whether long int is 64 bits... no
> checking whether long long int is 64 bits... yes
> checking for swig... /usr/bin/swig
> checking for SWIG version... 2.0.4
> configure: SWIG executable is '/usr/bin/swig'
> configure: SWIG library directory is '/usr/share/swig2.0'
> checking for python... /usr/bin/python
> checking for python version... 2.7
> checking for python platform... linux2
> checking for python script directory... ${prefix}/lib/python2.7/site-packages
> checking for python extension module directory...
> ${exec_prefix}/lib/python2.7/site-packages
> checking for Python include path... /usr/include/python2.7
> checking for Python library path... /usr/lib/python2.7/config
> checking python extra libraries...
> checking OS-specific settings... configure: creating ./config.status
> config.status: creating Makefile
> config.status: creating capi/Makefile
> config.status: creating capi/geos_c.h
> config.status: creating doc/Doxyfile
> config.status: creating doc/Makefile
> config.status: creating macros/Makefile
> config.status: creating src/Makefile
> config.status: creating src/algorithm/Makefile
> config.status: creating src/algorithm/locate/Makefile
> config.status: creating src/algorithm/distance/Makefile
> config.status: creating src/geom/Makefile
> config.status: creating src/geom/prep/Makefile
> config.status: creating src/geom/util/Makefile
> config.status: creating src/geomgraph/Makefile
> config.status: creating src/geomgraph/index/Makefile
> config.status: creating include/Makefile
> config.status: creating include/geos/Makefile
> config.status: creating include/geos/algorithm/Makefile
> config.status: creating include/geos/algorithm/locate/Makefile
> config.status: creating include/geos/algorithm/distance/Makefile
> config.status: creating include/geos/geom/Makefile
> config.status: creating include/geos/geom/prep/Makefile
> config.status: creating include/geos/geom/util/Makefile
> config.status: creating include/geos/geomgraph/Makefile
> config.status: creating include/geos/geomgraph/index/Makefile
> config.status: creating include/geos/index/Makefile
> config.status: creating include/geos/index/bintree/Makefile
> config.status: creating include/geos/index/chain/Makefile
> config.status: creating include/geos/index/intervalrtree/Makefile
> config.status: creating include/geos/index/quadtree/Makefile
> config.status: creating include/geos/index/strtree/Makefile
> config.status: creating include/geos/index/sweepline/Makefile
> config.status: creating include/geos/io/Makefile
> config.status: creating include/geos/linearref/Makefile
> config.status: creating include/geos/noding/Makefile
> config.status: creating include/geos/noding/snapround/Makefile
> config.status: creating include/geos/operation/Makefile
> config.status: creating include/geos/operation/buffer/Makefile
> config.status: creating include/geos/operation/distance/Makefile
> config.status: creating include/geos/operation/linemerge/Makefile
> config.status: creating include/geos/operation/overlay/Makefile
> config.status: creating include/geos/operation/overlay/snap/Makefile
> config.status: creating include/geos/operation/polygonize/Makefile
> config.status: creating include/geos/operation/predicate/Makefile
> config.status: creating include/geos/operation/relate/Makefile
> config.status: creating include/geos/operation/sharedpaths/Makefile
> config.status: creating include/geos/operation/union/Makefile
> config.status: creating include/geos/operation/valid/Makefile
> config.status: creating include/geos/planargraph/Makefile
> config.status: creating include/geos/planargraph/algorithm/Makefile
> config.status: creating include/geos/precision/Makefile
> config.status: creating include/geos/simplify/Makefile
> config.status: creating include/geos/util/Makefile
> config.status: creating include/geos/version.h
> config.status: creating src/index/Makefile
> config.status: creating src/index/bintree/Makefile
> config.status: creating src/index/chain/Makefile
> config.status: creating src/index/intervalrtree/Makefile
> config.status: creating src/index/quadtree/Makefile
> config.status: creating src/index/strtree/Makefile
> config.status: creating src/index/sweepline/Makefile
> config.status: creating src/io/Makefile
> config.status: creating src/linearref/Makefile
> config.status: creating src/noding/Makefile
> config.status: creating src/noding/snapround/Makefile
> config.status: creating src/operation/Makefile
> config.status: creating src/operation/buffer/Makefile
> config.status: creating src/operation/distance/Makefile
> config.status: creating src/operation/linemerge/Makefile
> config.status: creating src/operation/overlay/Makefile
> config.status: creating src/operation/polygonize/Makefile
> config.status: creating src/operation/predicate/Makefile
> config.status: creating src/operation/relate/Makefile
> config.status: creating src/operation/sharedpaths/Makefile
> config.status: creating src/operation/union/Makefile
> config.status: creating src/operation/valid/Makefile
> config.status: creating src/planargraph/Makefile
> config.status: creating src/precision/Makefile
> config.status: creating src/simplify/Makefile
> config.status: creating src/util/Makefile
> config.status: creating swig/geos.i
> config.status: creating swig/Makefile
> config.status: creating swig/python/Makefile
> config.status: creating swig/python/tests/Makefile
> config.status: creating swig/ruby/Makefile
> config.status: creating swig/ruby/test/Makefile
> config.status: creating php/Makefile
> config.status: creating php/test/Makefile
> config.status: creating tests/Makefile
> config.status: creating tests/bigtest/Makefile
> config.status: creating tests/unit/Makefile
> config.status: creating tests/perf/Makefile
> config.status: creating tests/perf/operation/Makefile
> config.status: creating tests/perf/operation/buffer/Makefile
> config.status: creating tests/perf/operation/predicate/Makefile
> config.status: creating tests/perf/capi/Makefile
> config.status: creating tests/xmltester/Makefile
> config.status: creating tests/geostest/Makefile
> config.status: creating tests/thread/Makefile
> config.status: creating tools/Makefile
> config.status: creating tools/geos-config
> config.status: creating include/config.h
> config.status: include/config.h is unchanged
> config.status: creating include/geos/platform.h
> config.status: include/geos/platform.h is unchanged
> config.status: executing depfiles commands
> config.status: executing libtool commands
> Swig: true
> Python bindings: true
> Ruby bindings: false
> PHP bindings: false
> after make and installing no bindings...
> ideas?
> thanks in advance
> p
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
