[geos-devel] [GEOS] #673: You can configure with --enable-python and no swig, but build fails
GEOS geos-trac at osgeo.org
Tue Nov 19 00:18:22 PST 2013
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.3
Component:  Default     |     Version:  3.4.2
 Severity:  Unassigned  |    Keywords:
 There's no error raised by ./configure if you pass --enable-python but no
 swig is found on the system. But at "make" time you get:
 Making all in python
 make[3]: Entering directory `/usr/src/geos/geos-trunk/b/swig/python'
 SWIG is disabled, can't build geos_wrap.cxx
 make[3]: *** [geos_wrap.cxx] Error 1
Ticket URL: <http://trac.osgeo.org/geos/ticket/673>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
