[geos-devel] Ask for help on building static library for GEOS on armv7 & armv7s architecture
kissv
kissv.eri at gmail.com
Thu Oct 17 01:35:15 PDT 2013
I have downloaded the GEOS package(version 3.2.2) from the website http://trac.osgeo.org/geos/, but i was failed to build the static library on armv7 & armv7s by using the "configure" and "make" tool.
The command I used is listed as follow:
$ ./configure --host=armv7-apple-darwin
$ make
$ sudo make install
however, when I was checking the library file, I found it is x86_64 architecture. Since I have not used the "configure" and "make" tool before, I must have done something wrong in the process.
So would you please give me some help on this?
Thanks a lot!
Eri Chen
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20131017/512967d1/attachment.html>
