[geos-devel] [GEOS] #699: Optimize Geometry->Intersection with rectangular argument
geos-trac at osgeo.org
Fri Aug 22 10:46:19 PDT 2014
Reporter: strk | Owner: geos-devel@…
Type: enhancement | Status: new
Priority: major | Milestone: 3.4.3
Component: Default | Version: 3.4.2
Severity: Unassigned | Keywords:
Intersection involving a rectangle could be optimized using rectangle
predicates. I've tested it for queries against large (~1.5 million
vertices in ~200k component polygons) and it takes the timing down from
~2000 seconds to less than 3 seconds...
Ticket URL: <http://trac.osgeo.org/geos/ticket/699>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
