[geos-devel] [GEOS] #699: Optimize Geometry->Intersection with rectangular argument
Sandro Santilli
strk at keybit.net
Wed Aug 27 01:09:57 PDT 2014
> This spring we needed GEOS clipping functionality for rendering maps.
> Unfortunately GEOS failed to clip the ~3 million vertex ESRI Europe map
> data, which was key for us, it gave up after about 6 seconds. A quick
> look at the GEOS code revealed there was no special code for rectangular
> clipping. Since we were in a hurry, we wrote the needed code ourselves.
> The resulting code could clip the ESRI data in 0.05 seconds.
> The code
> o was written to use OGR/GDAL objects directly. OGR converts its
> geometries to GEOS geometries for more complex tasks, we thought
> this was an unnecessary step for us. However, there should be
> no reason why converting to code to use GEOS objects would not
> be fairly easy.
> o allows for two kinds of clipping:
> - a polygon remains a polygon if any part of it is inside
> the clipping rectangle. The resulting polygon will follow the
> edges of the clipping rectangle to maintain the geometry.
> - a polygon may become a linestring if any part of it is
> outside the clipping rectangle.
If I understood it correctly the second kind would be equivalent
to the first kind applied to the boundary of the polygon (clipping
lines instead of polygons).
> o handles all special cases we could imagine on paper such as
> edges entering the rectangle from a corner. There are about
> 150 tests for such special cases.
That's great !
> o should be very robust, but we're not experts on that.
> The code is fast for clipping geometries typical in mapping, we
> did not consider vastly complex cases which might be mostly of
> academic interest. For example, if a geometry component begins with a
> coordinate to the left of the clipping rectangle, only one coordinate
> comparison is used to decide whether the next vertex is still to the
> left.
Neat
> We do not have any benchmarks on how our code compares with other
> resources, apart for the GEOS failure we encountered.
> If there is interest in our code, we can contribute some time to
> integrate it with GEOS, but would mostly likely need co-operation from
> someone already working with GEOS.
> Mika Heiskanen / Finnish Meteorological Institute
I'm very interested in your code and willing to help with integration.
I guess this could be a RectangleIntersection class under a new
geos::operation::intersection namespace, eventually further wrapped
by a generic IntersectionOp using RectangleIntersection when an input
is a rectangle or the generic OverlayOp in other cases.
Then Geometry::intersection would be using that specialized class.
Please let me know how I can help with this.
PS: I added Dr.JTS in CC, as he might be interested about this for JTS too
--strk;
() ASCII ribbon campaign -- Keep it simple !
/\ http://strk.keybit.net/rants/ascii_mails.txt
