[geos-devel] [GEOS] #699: Optimize Geometry->Intersection with rectangular argument
Rémi Cura
remi.cura at gmail.com
Wed Aug 27 01:46:18 PDT 2014
2014-08-27 10:09 GMT+02:00 Sandro Santilli <strk at keybit.net>:
> > This spring we needed GEOS clipping functionality for rendering maps.
> > Unfortunately GEOS failed to clip the ~3 million vertex ESRI Europe map
> > data, which was key for us, it gave up after about 6 seconds. A quick
> > look at the GEOS code revealed there was no special code for rectangular
> > clipping. Since we were in a hurry, we wrote the needed code ourselves.
> > The resulting code could clip the ESRI data in 0.05 seconds.
> > The code
> > o was written to use OGR/GDAL objects directly. OGR converts its
> > geometries to GEOS geometries for more complex tasks, we thought
> > this was an unnecessary step for us. However, there should be
> > no reason why converting to code to use GEOS objects would not
> > be fairly easy.
> > o allows for two kinds of clipping:
> > - a polygon remains a polygon if any part of it is inside
> > the clipping rectangle. The resulting polygon will follow the
> > edges of the clipping rectangle to maintain the geometry.
> > - a polygon may become a linestring if any part of it is
> > outside the clipping rectangle.
> If I understood it correctly the second kind would be equivalent
> to the first kind applied to the boundary of the polygon (clipping
> lines instead of polygons).
> > o handles all special cases we could imagine on paper such as
> > edges entering the rectangle from a corner. There are about
> > 150 tests for such special cases.
> That's great !
> > o should be very robust, but we're not experts on that.
> > The code is fast for clipping geometries typical in mapping, we
> > did not consider vastly complex cases which might be mostly of
> > academic interest. For example, if a geometry component begins with a
> > coordinate to the left of the clipping rectangle, only one coordinate
> > comparison is used to decide whether the next vertex is still to the
> > left.
> Neat
> > We do not have any benchmarks on how our code compares with other
> > resources, apart for the GEOS failure we encountered.
> > If there is interest in our code, we can contribute some time to
> > integrate it with GEOS, but would mostly likely need co-operation from
> > someone already working with GEOS.
> > Mika Heiskanen / Finnish Meteorological Institute
> I'm very interested in your code and willing to help with integration.
> I guess this could be a RectangleIntersection class under a new
> geos::operation::intersection namespace, eventually further wrapped
> by a generic IntersectionOp using RectangleIntersection when an input
> is a rectangle or the generic OverlayOp in other cases.
> Then Geometry::intersection would be using that specialized class.
> Please let me know how I can help with this.
> PS: I added Dr.JTS in CC, as he might be interested about this for JTS too
> --strk;
This upgrade would be _much_ appreciated here.
Very good news, thanks !
Cheers,
Rémi-C
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20140827/533c174b/attachment.html>
