[geos-devel] GEOSVoronoiDiagram missing symbol
Sandro Santilli strk at keybit.net
Fri Aug 29 06:56:47 PDT 2014
On Fri, Aug 29, 2014 at 02:53:42PM +0100, Joshua Arnott wrote:
> I want to use the voronoi diagram functionality from the C API.
> The linker is complaining about the GEOSVoronoiDiagram not being found.
How did you build GEOS, which version of it ?
Did "make check" run correctly ?
--strk;
