[geos-devel] GEOSVoronoiDiagram missing symbol
Joshua Arnott
josh at snorfalorpagus.net
Fri Aug 29 07:27:03 PDT 2014
I’m using GEOS 3.4.2, built from source on OS X 10.9.4. I had this issue using the library built using Homebrew, but have since compiled manually with the same issue. Compiled with "./configure --disable-dependency-tracking --prefix=/usr/local”.
Results of “make check” below:
GEOS Test Suite Application
capi::GEOSBuffer: ....................
capi::GEOSContains: ...
capi::GEOSConvexHull: .
capi::GEOSCoordSeq: ......
capi::GEOSDelaunayTriangulation: ......
capi::GEOSDistance: .
capi::GEOSGeomFromWKB: .....
capi::GEOSGeomToWKT: .............
capi::GEOSGeom_create: .......
capi::GEOSGeom_extractUniquePoints: ...
capi::GEOSGetCentroid: .....
capi::GEOSInterrupt: ..NOTICE: InterruptedException: Interrupted!
capi::GEOSIntersects: ...NOTICE: IllegalArgumentException: RobustDeterminant encountered non-finite numbers
capi::GEOSLineStringPoint: ...
capi::GEOSNearestPoints: ..
capi::GEOSNode: ...
capi::GEOSOffsetCurve: .........NOTICE: IllegalArgumentException: Cannot get offset of single-vertex line
capi::GEOSOrientationIndex: ...........
capi::GEOSPointOnSurface: ......
capi::GEOSPolygonizeGetCutEdges: ..
capi::GEOSPreparedGeometry: ......
capi::GEOSRelateBoundaryNodeRule: .......NOTICE: Invalid boundary node rule 5
capi::GEOSRelatePatternMatch: .....NOTICE: IllegalArgumentException: Geometry is not lineal
capi::GEOSSharedPaths: ..NOTICE: IllegalArgumentException: Geometry is not lineal
capi::GEOSSimplify: .
capi::GEOSSnap: ..........
capi::GEOSUnaryUnion: ........NOTICE: IllegalArgumentException: EdgeEnd with coordinate nan nan invalid for node nan nan
capi::GEOSWithin: ...
capi::GEOSisValidDetail: ......
geos::algorithm::Angle: ....
geos::algorithm::CGAlgorithms::computeOrientation: ..
geos::algorithm::CGAlgorithms::isCCW: .....
geos::algorithm::CGAlgorithms::isPointInRing: ..
geos::algorithm::CGAlgorithms::signedArea: ...
geos::algorithm::ConvexHull: .......
geos::algorithm::InteriorPointArea: .
geos::algorithm::PointLocator: ....
geos::algorithm::RobustLineIntersection: ......
geos::algorithm::RobustLineIntersector: .............
geos::algorithm::distace::DiscreteHausdorffDistance: ....
geos::geom::Coordinate: .........
geos::geom::CoordinateArraySequence: .................
geos::geom::CoordinateArraySequenceFactory: [1=F]...
geos::geom::CoordinateList: ...
geos::geom::Dimension: .....
geos::geom::Envelope: .........
geos::geom::Geometry::clone: .......
geos::geom::Geometry::covers: ....
geos::geom::Geometry::isRectangle: .......
geos::geom::GeometryFactory: ....................................
geos::geom::IntersectionMatrix: .............................
geos::geom::LineSegment: ......
geos::geom::LineString: .........................
geos::geom::LinearRing: ..............................
geos::geom::Location: ...
geos::geom::MultiLineString: .
geos::geom::MultiPoint: ............................
geos::geom::MultiPolygon: .
geos::geom::Point: ........................................
geos::geom::Polygon: .....................................
geos::geom::PrecisionModel: .........
geos::geom::Triangle: .....
geos::geom::prep::PreparedGeometryFactory: .............................
geos::geom::util::GeometryExtracter: ..
geos::index::quadtree::DoubleBits: .
geos::io::ByteOrderValues: ...
geos::io::WKBReader: .......
geos::io::WKBWriter: ....
geos::io::WKTReader: .......
geos::io::WKTWriter: .....
geos::io::Writer: ....
geos::linearref::LocationIndexedLine: ...........................
geos::noding::BasicSegmentString: ....
geos::noding::NodedSegmentString: .....
geos::noding::OrientedCoordinateArray: .....
geos::noding::SegmentNode: ....
geos::noding::SegmentPointComparator: .....
geos::noding::snapround::HotPixel: ...
geos::noding::snapround::MCIndexSnapRounder: .
geos::operation::IsSimpleOp: ...
geos::operation::buffer::BufferBuilder: .
geos::operation::buffer::BufferOp: ...........
geos::operation::buffer::BufferParameters: ..........
geos::operation::distance::DistanceOp: ...................
geos::operation::geounion::CascadedPolygonUnion: .
geos::operation::geounion::UnaryUnionOp: ......
geos::operation::linemerge::LineMerger: ......
geos::operation::linemerge::LineSequencer: ............
geos::operation::overlay::snap::GeometrySnapper: ..
geos::operation::overlay::snap::LineStringSnapper: .......
geos::operation::overlay::validate::FuzzyPointLocator: .......
geos::operation::overlay::validate::OffsetPointGenerator: .....
geos::operation::overlay::validate::OverlayResultValidator: ......
geos::operation::polygonize::Polygonizer: ..
geos::operation::sharedpaths::SharedPathsOp: .....................
geos::operation::valid::IsValidOp: .
geos::operation::valid::ValidClosedRing: .....
geos::operation::valid::ValidSelfTouchingRingFormingHole: .......
geos::precision::GeometryPrecisionReducer: .........
geos::precision::SimpleGeometryPrecisionReducer: .......
geos::simplify::DouglasPeuckerSimplifier: ...........
geos::simplify::TopologyPreservingSimplifier: ...............
geos::triangulate::Delaunay: .........
geos::triangulate::quadedge::QuadEdge: ...
geos::triangulate::quadedge::QuadEdgeSubdivision: .
geos::util::UniqueCoordinateArrayFilter: .
---> group: geos::geom::CoordinateArraySequenceFactory, test: test<1>
problem: assertion failed
tests summary: failures:1 ok:836
FAIL: geos_unit
1 of 1 test failed
make[4]: *** [check-TESTS] Error 1
make[3]: *** [check-am] Error 2
make[2]: *** [check-recursive] Error 1
make[1]: *** [check-recursive] Error 1
make: *** [check] Error 2
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20140829/73ee6b78/attachment-0001.html>
